EntityColor 属性 (ActiveX)
指定真颜色的颜色值。 支持的平台:仅限 Windows 属性值只读:不 类型:长 真彩色的颜色值。 言论此属性指定颜色的 32 位部分。AcCmEntityColor 例子VBA: Sub Example_EntityColor()
Dim line As AcadLine
Set line = CreateLine
Dim color As AcadAcCmColor
Set color = line.TrueColor
Dim y As Long
y = MakeLong(MakeWord(194, 122), MakeWord(133, 144))
color.EntityColor = y
line.TrueColor = color
Dim retcolor As AcadAcCmColor
Set retcolor = line.TrueColor
Dim x As Long
x = retcolor.EntityColor
Dim BreakLong(3) As Byte
BreakLong(0) = x And &HFF&
BreakLong(1) = (x And &HFF00&) \ &H100&
BreakLong(2) = (x And &HFF0000) \ &H10000
BreakLong(3) = (x And &H7F000000) \ &H1000000
If x < 0 Then BreakLong(3) = BreakLong(3) Or &H80
MsgBox "ColorMethod = " & BreakLong(3) & vbCrLf & _
"Red = " & BreakLong(2) & vbCrLf & _
"Green = " & BreakLong(1) & vbCrLf & _
"Blue = " & BreakLong(0)
Private Function CreateLine() As AcadLine
Dim lineObj As AcadLine
startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
Set CreateLine = lineObj
ZoomAll
End Function
Private Function MakeLong(WordHi As Variant, WordLo As Integer) As Long
' High word is coerced to a variant on the call, to allow
' it to overflow the limits of multiplication, which shifts
' it left.
MakeLong = (WordHi * &H10000) + (WordLo And &HFFFF&)
End Function
Private Function MakeWord(ByteHi As Byte, ByteLo As Byte) As Integer
' If the high byte would push the final result out of the
' signed integer range, it must be slid back.
If ByteHi > &H7F Then
MakeWord = ((ByteHi * &H100&) + ByteLo) - &H10000
Else
MakeWord = (ByteHi * &H100&) + ByteLo
End If
End Function
可视化 LISP: (vl-load-com)
(defun c:Example_EntityColor()
doc (vla-get-ActiveDocument acadObj))
(setq modelSpace (vla-get-ModelSpace doc)
line (CreateLine)
color (vla-get-TrueColor line))
(setq y (MakeLong (MakeWord 194 122) (MakeWord 133 144)))
(vla-put-EntityColor color y)
(vla-put-TrueColor line color)
(setq retcolor (vla-get-TrueColor line))
(setq x (vla-get-EntityColor retcolor))
(setq BreakLong (vlax-make-safearray vlax-vbDouble '(0 . 3)))
(vlax-safearray-put-element BreakLong 0 (logand x 255))
(vlax-safearray-put-element BreakLong 1 (/ (logand x 65280) 256))
(vlax-safearray-put-element BreakLong 2 (/ (logand x 16711680) 65536))
(vlax-safearray-put-element BreakLong 3 (/ (logand x 2130706432) 16777216))
(if (< x 0)
(vlax-safearray-put-element BreakLong 3 (logior (fix (vlax-safearray-get-element BreakLong 3)) 128))
(alert (strcat "ColorMethod = " (itoa (fix (vlax-safearray-get-element BreakLong 3))) "\n"
"Red = " (itoa (fix (vlax-safearray-get-element BreakLong 2))) "\n"
"Green = " (itoa (fix (vlax-safearray-get-element BreakLong 1))) "\n"
"Blue = " (itoa (fix (vlax-safearray-get-element BreakLong 0)))))
(defun CreateLine()
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
lineObj (vla-AddLine modelSpace startPoint endPoint))
(vla-ZoomAll acadObj)
lineObj
(defun MakeLong (WordHi WordLo)
;; High word is coerced to a variant on the call, to allow
;; it to overflow the limits of multiplication, which shifts
;; it left.
(+ (* WordHi 65536) (logand WordLo 65535))
(defun MakeWord(ByteHi ByteLo)
;; If the high byte would push the final result out of the
;; signed integer range, it must be slid back.
(if (> ByteHi 127)
(- (+ (* ByteHi 256) ByteLo) 65536)
GMT+8, 2026-10-27 13:29
