DisplayLocked 属性 (ActiveX)
指定视口是否锁定。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_DisplayLocked()
' This example scans the current drawing paper space Viewports
' and displays whether or not any of them are locked.
Dim pviewportObj As Object
Dim msg As String, DisplayState As String
' Make sure this drawing contains paper space viewports before continuing
If ThisDrawing.PaperSpace.Count = 0 Then
MsgBox "There are no paper space viewports in the current drawing."
Exit Sub
End If
' Go through each PViewport object in the drawing paper space
' and determine whether the paper space viewport is locked or not
For Each pviewportObj In ThisDrawing.PaperSpace
' Determine if this is a paper space viewport
If pviewportObj.ObjectName = "AcDbViewport" Then
' Determine if this paper space viewport is clipped
DisplayState = IIf(pviewportObj.DisplayLocked, " is locked", " is not locked")
msg = msg & "PViewport ID " & pviewportObj.ObjectID & DisplayState & vbCrLf
End If
Next
' Display locked state of paper space Viewports
MsgBox msg
可视化 LISP: (vl-load-com)
(defun c:Example_DisplayLocked()
;; This example scans the current drawing paper space Viewports
;; and displays whether or not any of them are locked.
(setq paperSpace (vla-get-PaperSpace doc))
;; Make sure this drawing contains paper space viewports before continuing
(if (= (vla-get-count paperSpace) 0)
(alert "There are no paper space viewports in the current drawing.")
(progn
(setq msg "")
;; Go through each paper space viewport object in the drawing paper space
;; and determine whether or not it is locked
(vlax-for pviewportObj paperSpace
;; Determine whether this is a paper space viewport
(if (= (vla-get-ObjectName pviewportObj) "AcDbViewport")
(progn
;; Determine whether this paper space viewport is locked
(setq DisplayState (if (= (vla-get-DisplayLocked pviewportObj) :vlax-true) " is locked" " is not locked"))
(setq ID (itoa (vla-get-ObjectID pviewportObj)))
(setq msg (strcat msg "PViewport ID " ID DisplayState "\n"))
;; Display locked state of paper space Viewports
(alert msg)
GMT+8, 2026-11-16 04:39
