DisplayGrips 属性 (ActiveX)
控制“拉伸”、“移动”、“旋转”、“缩放”和“镜像”夹持模式的选择集夹点的显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 若要调整夹点的大小和光标在捕捉到夹点时使用的有效选择区域,请使用该属性。GripSize 要调整选定或未选定夹点的颜色,请使用 or 属性。GripColorSelectedGripColorUnselected 注意:此属性的值存储在 GRIPS 系统变量中。
例子VBA: Sub Example_DisplayGrips()
' This example reads and modifies the preference value that controls
' the display of selection set grips for the Stretch, Move, Rotate,
' Scale, and Mirror grip modes.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSelection
' Get the selection preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Selection
originalValue = ACADPref.DisplayGrips
MsgBox "The DisplayGrips preference is set to: " & originalValue
' Modify the DisplayGrips preference by toggling the value
ACADPref.DisplayGrips = Not (originalValue)
newValue = ACADPref.DisplayGrips
MsgBox "The DisplayGrips preference has been set to: " & newValue
' this preference in effect
ACADPref.DisplayGrips = originalValue
MsgBox "The DisplayGrips preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_DisplayGrips()
;; This example reads and modifies the preference value that controls
;; the display of selection set grips for the Stretch, Move, Rotate,
;; Scale, and Mirror grip modes.
;; When finished, this example resets the preference value back to
;; its original value.
;; Get the selection preferences object
(setq ACADPref (vla-get-Selection preferences))
(setq originalValue (vla-get-DisplayGrips ACADPref))
(alert (strcat "The DisplayGrips preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the DisplayGrips preference by toggling the value
(vla-put-DisplayGrips ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-DisplayGrips ACADPref))
(alert (strcat "The DisplayGrips preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-DisplayGrips ACADPref originalValue)
(alert (strcat "The DisplayGrips preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-16 02:03
