Database 属性 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 1062| 评论: 0|原作者: admin|来自: AutoCAD
获取对象所属的数据库。
object.Database
类别: 文档
此属性应用于的对象。
只读:是的
类型: 数据库
包含对象的对象。Database
Sub Example_Database()
    ' This example references the Database object obtained from model space.
    ' Information from the Database object is then displayed
    Dim Database As AcadDatabase
    ' Attach to Database object
    Set Database = ThisDrawing.ModelSpace.Database
    MsgBox "We now have access to the properties and methods of the Database object!"
    ' Retrieve the number of Blocks in this database
    MsgBox "The number of Blocks in this database is: " & Database.Blocks.Count
    ' Release object
    Set Database = Nothing
    MsgBox "The Database object has been released!"
(defun c:Example_Database()
    ;; This example references the Database object obtained from model space.
    ;; Information from the Database object is then displayed
    ;; Attach to Database object
    (setq database (vla-get-Database (vla-get-ModelSpace doc)))
    (alert "We now have access to the properties and methods of the Database object!")
    ;; Retrieve the number of Blocks in this database
    (alert (strcat "The number of Blocks in this database is: " (itoa (vla-get-Count (vla-get-Blocks database)))))
    ;; Release object
    (vlax-release-object database)
    (alert "The Database object has been released!")
GMT+8, 2026-11-16 03:19
