Coordinate 属性 (ActiveX)
指定对象中单个顶点的坐标。 支持的平台:仅限 Windows 签名VBA: object.Coordinate(index)
只读:
类型:变体(三元素或双元素双精度数组) 指定顶点的 X、Y 和 Z 坐标数组。 LightweightPolyline 对象:变体有两个元素,分别表示 OCS 中的 X 和 Y 坐标。 折线对象:变体有三个元素,分别表示 OCS 中的 X 和 Y 坐标。Z 坐标存在于变体中,但被忽略。 所有其他对象:变体有三个元素,表示 WCS 中的 X 和 Y 坐标;在活动UCS上,Z坐标将默认为0。 言论此属性将替换指定对象的任何现有顶点。使用标准数组处理技术来处理此属性中包含的值。 3DPolyline、折线、多边形网格:对于简单折线(非样条线或曲线拟合),此属性指定简单折点。对于样条线或曲线拟合折线,此属性指定控制点折点。 可以使用该方法将折线和对象的 OCS 坐标与其他坐标系相互转换。LightweightPolylineTranslateCoordinates 例子VBA: Sub Example_Coordinate()
' This example creates a polyline in model space and
' queries and changes the coordinate in the first index position.
Dim plineObj As AcadPolyline
Dim points(0 To 14) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
' Create a lightweight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
ZoomAll
' Find the coordinate in the first index position
Dim coord As Variant
coord = plineObj.Coordinate(0)
MsgBox "The coordinate in the first index position of the polyline is: " & coord(0) & ", " _
& coord(1) & ", " & coord(2)
' Change the coordinate
coord(0) = coord(0) + 1
plineObj.Coordinate(0) = coord
plineObj.Update
' Query the new coordinate
MsgBox "The coordinate in the first index position of the polyline is now: " & coord(0) & ", " _
可视化 LISP: (vl-load-com)
(defun c:Example_Coordinate()
;; This example creates a polyline in model space and
;; queries and changes the coordinate in the first index position.
doc (vla-get-ActiveDocument acadObj))
;; Define the 2D polyline points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 14)))
(vlax-safearray-fill points '(1 1 0
1 2 0
2 2 0
3 2 0
4 4 0
;; Create a lightweight Polyline object in model space
(setq modelSpace (vla-get-ModelSpace doc)
plineObj (vla-AddPolyline modelSpace points))
(vla-ZoomAll acadObj)
;; Find the coordinate in the first index position
(setq coord (vlax-safearray->list (vlax-variant-value (vla-get-Coordinate plineObj 0))))
(alert (strcat "The coordinate in the first index position of the polyline is: "
(rtos (nth 0 coord) 2) ", " (rtos (nth 1 coord) 2) ", " (rtos (nth 2 coord) 2)))
;; Change the coordinate
(setq newCoord (vlax-make-safearray vlax-vbDouble '(0 . 2)))
(vlax-safearray-fill newCoord (list (+ (nth 0 coord) 1)
(nth 1 coord)
(nth 2 coord)))
(vla-put-Coordinate plineObj 0 newCoord)
(vla-Update plineObj)
; Query the new coordinate
(alert (strcat "The coordinate in the first index position of the polyline is now: "
GMT+8, 2026-11-16 03:54
