ColorName 属性 (ActiveX)
指定颜色的名称(如果有)。 支持的平台:仅限 Windows 属性值只读:是的 类型:字符串 颜色名称。 言论没有其他评论。 例子VBA: Sub Example_ColorName()
'This example draws a circle and
'returns the color name and color book name of the color.
Dim cir As AcadCircle
Dim pt(0 To 2) As Double
Set cir = ThisDrawing.ModelSpace.AddCircle(pt, 2)
Dim col As AcadAcCmColor
Set col = cir.TrueColor
col.SetRGB 125, 175, 235
col.SetNames "MyColor", "MyColorBook"
cir.TrueColor = col
ZoomAll
Dim retCol As AcadAcCmColor
Set retCol = cir.TrueColor
MsgBox "BookName=" & col.BookName & vbLf & _
"ColorName=" & col.ColorName
可视化 LISP: (vl-load-com)
(defun c:Example_ColorName()
;; This example draws a circle and
;; returns the color name and color book name of the color.
doc (vla-get-ActiveDocument acadObj))
(setq pt (vlax-3d-point 0 0 0))
(setq modelSpace (vla-get-ModelSpace doc)
cir (vla-AddCircle modelSpace pt 2)
col (vla-get-TrueColor cir))
(vla-SetRGB col 125 175 235)
(vla-SetNames col "MyColor" "MyColorBook")
(vla-put-TrueColor cir col)
(vla-ZoomAll acadObj)
(setq retCol (vla-get-TrueColor cir))
(alert (strcat "BookName=" (vla-get-BookName retCol)
"\nColorName=" (vla-get-ColorName retCol)))
GMT+8, 2026-11-16 04:09
