ColorMethod 属性 (ActiveX)
指定颜色方法。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acColorMethod 默认颜色方法为 。要直接确定颜色的设置方式,请使用此处列出的常量:acColorMethodByLayer
言论没有其他评论。 例子VBA: Sub Example_ColorMethod()
' This example shows how to change the
' ColorMethod property
' Circle number one
Dim cir1 As AcadCircle
Dim pt(0 To 2) As Double
Set cir1 = ThisDrawing.modelSpace.AddCircle(pt, 2)
Dim col As AcadAcCmColor
Set col = cir1.TrueColor
col.ColorMethod = AutoCAD.acColorMethodForeground
cir1.TrueColor = col
ZoomAll
Dim retCol As AcadAcCmColor
Set retCol = cir1.TrueColor
' Message box with method and index
Dim MethodText As String
MethodText = col.ColorMethod
MsgBox "ColorMethod=" & MethodText & vbCrLf & "Index=" & col.ColorIndex
' Circle number two
Dim cir2 As AcadCircle
Set cir2 = ThisDrawing.modelSpace.AddCircle(pt, 6)
ZoomAll
col.ColorMethod = AutoCAD.acColorMethodByBlock
' Circle number three
Dim cir3 As AcadCircle
Set cir3 = ThisDrawing.modelSpace.AddCircle(pt, 10)
ZoomAll
Dim layColor As AcadAcCmColor
Set layColor = ThisDrawing.ActiveLayer.TrueColor
layColor.SetRGB 122, 199, 25
ThisDrawing.ActiveLayer.TrueColor = layColor
col.ColorMethod = AutoCAD.acColorMethodByLayer
Set retCol = cir3.TrueColor
可视化 LISP: (vl-load-com)
(defun c:Example_ColorMethod()
;; This example shows how to change the
;; ColorMethod property
doc (vla-get-ActiveDocument acadObj)
modelSpace (vla-get-ModelSpace doc))
;; Circle number one
(setq pt (vlax-3d-point 0 0 0))
(setq cir1 (vla-AddCircle modelSpace pt 2)
col (vla-get-TrueColor cir1))
(vla-put-ColorMethod col acColorMethodForeground)
(vla-put-TrueColor cir1 col)
(vla-ZoomAll acadObj)
(vla-Regen doc :vlax-true)
(setq retCol (vla-get-TrueColor cir1))
;; Message box with method and index
(setq MethodText (vla-get-ColorMethod col))
(alert (strcat "ColorMethod=" (itoa MethodText) "\nIndex=" (itoa (vla-get-ColorIndex col))))
;; Circle number two
(setq cir2 (vla-AddCircle modelSpace pt 6))
(vla-put-ColorMethod col acColorMethodByBlock)
;; Circle number three
(setq cir3 (vla-AddCircle modelSpace pt 10))
(setq layColor (vla-get-TrueColor (vla-get-ActiveLayer doc)))
(vla-SetRGB layColor 122 199 25)
(vla-put-TrueColor (vla-get-ActiveLayer doc) layColor)
(vla-put-ColorMethod col acColorMethodByLayer)
(setq retCol (vla-get-TrueColor cir3))
;;Message box with method and index
GMT+8, 2026-11-16 04:11
