ColorIndex 属性 (ActiveX)
指定颜色索引。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acColor 默认颜色名称为 。使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:acByLayer
言论没有其他评论。 例子VBA: Sub Example_ColorIndex()
'This example draws a circle and
'returns the closest color index.
Dim cir As AcadCircle
Dim pt(0 To 2) As Double
Set cir = ThisDrawing.modelSpace.AddCircle(pt, 2)
Dim col As AcadAcCmColor
Set col = cir.TrueColor
col.SetRGB 125, 175, 235
cir.TrueColor = col
ZoomAll
Dim retCol As AcadAcCmColor
Set retCol = cir.TrueColor
If col.ColorMethod = AutoCAD.acColorMethodByRGB Then
MsgBox "Closest ColorIndex=" & col.ColorIndex
End If
可视化 LISP: (vl-load-com)
(defun c:Example_ColorIndex()
;;This example draws a circle and
;;returns the closest color index.
doc (vla-get-ActiveDocument acadObj))
(setq pt (vlax-3d-point 0 0 0))
(setq modelSpace (vla-get-ModelSpace doc)
cir (vla-AddCircle modelSpace pt 2)
col (vla-get-TrueColor cir))
(vla-SetRGB col 125 175 235)
(vla-put-TrueColor cir col)
(vla-ZoomAll acadObj)
(setq retCol (vla-get-TrueColor cir))
(if (= (vla-get-ColorMethod col) acColorMethodByRGB)
(alert (strcat "Closest ColorIndex=" (itoa (vla-get-ColorIndex col))))
GMT+8, 2026-11-16 04:28
