Closed 属性 (ActiveX)
指定 3D 折线、轻量级折线、放样曲面、折线或样条是打开还是闭合。 支持的平台:仅限 Windows 属性值只读:
类型:布尔
言论![]() 开放的 3D 折线 ![]() 闭合的 3D 折线 如果确定其轮廓的横截面曲线闭合,则放样曲面闭合。例如,如果在放样轮廓中使用圆弧,则生成的曲面是开放的。如果使用闭合曲线(如圆)进行放样,则生成的曲面是闭合的。 例子VBA: Sub Example_Closed()
' This example creates a polyline and then toggles the
' setting to Closed.
Dim plineObj As AcadPolyline
Dim closedState As String
' Create the polyline
Dim points(8) As Double
points(0) = 3: points(1) = 7: points(2) = 0
points(3) = 9: points(4) = 2: points(5) = 0
points(6) = 3: points(7) = 5: points(8) = 0
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
' Set the closed property to True
plineObj.Closed = True ' Close Polyline
ThisDrawing.Regen (True)
GoSub DISPLAY
' Open the PolyLine by setting the closed property to False
plineObj.Closed = False ' Open Polyline
GoSub DISPLAY
Exit Sub
DISPLAY:
' Retrieve and display the Closed property
closedState = IIf(plineObj.Closed, "Closed", "Open")
MsgBox "The new Polyline is: " & closedState, vbInformation, "Closed Example"
Return
可视化 LISP: (vl-load-com)
(defun c:Example_Closed()
;; This example creates a polyline and then toggles the
;; setting to Closed.
;; Create the polyline
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill points '(3 7 0
9 2 0
3 5 0
(setq plineObj (vla-AddPolyline modelSpace points))
;; Set the closed property to True
(vla-put-Closed plineObj :vlax-true) ;; Close Polyline
(vla-Regen doc :vlax-true)
;; Retrieve and display the Closed property
(setq closedState (if (= (vla-get-Closed plineObj) :vlax-true) "Closed" "Open"))
(alert (strcat "The new Polyline is: " closedState))
;; Open the PolyLine by setting the closed property to False
(vla-put-Closed plineObj :vlax-false) ;; Open Polyline
GMT+8, 2026-11-16 04:02
