CanonicalMediaName 属性 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 1029| 评论: 0|原作者: admin|来自: AutoCAD
按名称指定纸张尺寸。
object.CanonicalMediaName
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:字符串
纸张尺寸的名称。
在重新生成图形之前,对此属性的更改将不可见。使用该方法重新生成图形。Regen
Sub Example_CanonicalMediaName()
    ' This example finds the name of the media for the active layout
    Dim MediaName As String
    MediaName = ThisDrawing.ActiveLayout.CanonicalMediaName
    If MediaName = "" Then
        MsgBox "There is no media set for the active layout."
    Else
        MsgBox "The media for the active layout is: " & MediaName
    End If
(defun c:Example_CanonicalMediaName()
    ;; This example finds the name of the media for the active layout
    (setq MediaName (vla-get-CanonicalMediaName (vla-get-ActiveLayout doc)))
    (if (/= MediaName "")
        (alert "There is no media set for the active layout.")
        (alert (strcat "The media for the active layout is: " MediaName))
GMT+8, 2026-11-16 01:59
