ActiveProfile 属性 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 780| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 任务的活动配置文件。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
object.ActiveProfile
类型:PreferencesProfiles
此属性应用于的对象。
只读:不
类型:字符串
活动配置文件的名称。
Sub Example_ActiveProfile()
    ' ActiveProfile.
    Dim currActiveProfile As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current ActiveProfile value
    currActiveProfile = preferences.Profiles.ActiveProfile
    MsgBox "The current value for ActiveProfile is " & currActiveProfile, vbInformation, "ActiveProfile Example"
(defun c:Example_ActiveProfile()
    ;; ActiveProfile.
          preferences (vla-get-Preferences acadObj))
    ;; Retrieve the current ActiveProfile value
    (setq currActiveProfile (vla-get-ActiveProfile (vla-get-Profiles preferences)))
    (alert (strcat "The current value for ActiveProfile is " currActiveProfile))
GMT+8, 2026-11-16 02:52
