UnloadDVB 方法 (ActiveX)
卸载指定的 AutoCAD VBA 项目文件。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_LoadDVB()
' This example loads a DVB file and runs a macro
' contained in the file using the RunMacro method.
' This example uses a DVB file named drawline.dvb.
' You should change the example to use a file on your computer.
' * Note: If you open a DVB file and then run the example to load it, there will be an error
' when the DVB file is unloaded.
Dim FileName As String
FileName = "c:\drawline.dvb"
' Load a sample VBA project DVB file
LoadDVB FileName
' Run the drawline sample macro
RunMacro "Module1.Drawline"
' Unload the drawline VBA project DVB file now.
UnloadDVB FileName
MsgBox "The DVB file has been run!"
可视化 LISP: (vl-load-com)
(defun c:Example_LoadDVB()
;; This example loads a DVB file and runs a macro
;; contained in the file using the RunMacro method.
;; This example uses a DVB file named drawline.dvb.
;; You should change the example to use a file on your computer.
;; * Note: If you open a DVB file and then run the example to load it, there will be an error
;; when the DVB file is unloaded.
(setq FileName (findfile ".\\Sample\\VBA\\drawline.dvb"))
;; Load a sample VBA project DVB file
(vla-LoadDVB acadObj FileName)
;; Run the drawline sample macro
(vla-RunMacro acadObj "Module1.Drawline")
;; Unload the drawline VBA project DVB file now.
(vla-UnloadDVB acadObj FileName)
(alert "The DVB file has been run!")
GMT+8, 2026-10-27 15:07
