SetBackgroundColor2 方法 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 688| 评论: 0|原作者: admin|来自: AutoCAD
设置指定命名单元格样式的背景颜色值。
object.SetBackgroundColor2 bstrCellStyle, color
类型:TableStyle
此方法应用到的对象。
bstrCellStyle
访问:仅输入
类型:字符串
命名单元格样式。
颜色
访问:仅输入
类型:AcCmColor
要应用于指定单元格样式的 AutoCAD 真彩色对象。
返回值 (RetVal)
无返回值。
Sub Example_SetBackgroundColor2()
    ' the style name and other attributes.
    Dim dictObj As AcadDictionary
    ' Get the current TableStyle object
    Dim tableStyle As AcadTableStyle
    Set tableStyle = dictObj.Item(ThisDrawing.GetVariable("CTABLESTYLE"))
    Dim colCurrent As AcadAcCmColor, colRowCurrent As AcadAcCmColor, colNoneCurrent As Boolean
    Set colCurrent = tableStyle.GetBackgroundColor2("Title")
    Set colRowCurrent = tableStyle.GetColor2("Data")
    colNoneCurrent = tableStyle.GetBackgroundColorNone(acHeaderRow)
    MsgBox "Table colors " & vbLf & _
           "Background ACI value = " & colCurrent.ColorIndex & vbLf & _
           "Row Text ACI value = " & colRowCurrent.ColorIndex & vbLf & _
           "Background None = " & colNoneCurrent
    Dim col As AcadAcCmColor
    Set col = tableStyle.GetBackgroundColor(acTitleRow)
    col.SetRGB 0, 0, 255
    tableStyle.SetBackgroundColor2 "Title", col
    col.SetRGB 255, 0, 0
    tableStyle.SetColor2 "Data", col
    If colNoneCurrent = False Then
        tableStyle.SetBackgroundColorNone acHeaderRow, True
    Else
        tableStyle.SetBackgroundColorNone acHeaderRow, False
    End If
    Dim colNew As AcadAcCmColor, colRowNew As AcadAcCmColor, colNoneNew As Boolean
    Set colNew = tableStyle.GetBackgroundColor2("Title")
    Set colRowNew = tableStyle.GetColor2("Data")
    colNoneNew = tableStyle.GetBackgroundColorNone(acHeaderRow)
           "Background ACI value = " & colNew.ColorIndex & vbLf & _
           "Row Text ACI value = " & colRowNew.ColorIndex & vbLf & _
           "Background None = " & colNoneNew
    tableStyle.SetBackgroundColor2 "Title", colCurrent
    tableStyle.SetColor2 "Data", colRowCurrent
    tableStyle.SetBackgroundColorNone acHeaderRow, colNoneCurrent
    MsgBox "Reset the table style back to its original values."
(defun c:Example_SetBackgroundColor2()
    ;; the style name and other attributes.
          doc (vla-get-ActiveDocument acadObj))
    (setq dictionaries (vla-get-Dictionaries doc)
          dictObj (vla-Item dictionaries "acad_tablestyle"))
    ;; Get the current TableStyle object
    (setq tableStyle (vla-Item dictObj (vla-GetVariable doc "CTABLESTYLE")))
    (setq colCurrent (vla-GetBackgroundColor2 tableStyle "Title")
          colRowCurrent (vla-GetColor2 tableStyle "Data")
          colNoneCurrent (vla-GetBackgroundColorNone tableStyle acHeaderRow))
    (alert (strcat "Table colors \n"
                   "Background ACI value = " (itoa (vla-get-ColorIndex colCurrent)) "\n"
                   "Row Text ACI value = " (itoa (vla-get-ColorIndex colRowCurrent)) "\n"
                   "Background None = " (if (= colNoneCurrent :vlax-true) "True" "False")))
    (setq col (vla-GetBackgroundColor2 tableStyle "Title"))
    (vla-SetRGB col 0 0 255)
    (vla-SetBackgroundColor2 tableStyle "Title" col)
    (vla-SetRGB col 255 0 0)
    (vla-SetColor2 tableStyle "Data" col)
    (vla-SetBackgroundColorNone tableStyle acHeaderRow (if (= colNoneCurrent :vlax-true) :vlax-false :vlax-true))
    (setq colNew (vla-GetBackgroundColor2 tableStyle "Title")
          colRowNew (vla-GetColor2 tableStyle "Data")
          colNoneNew (vla-GetBackgroundColorNone tableStyle acHeaderRow))
                   "Background ACI value = " (itoa (vla-get-ColorIndex colNew)) "\n"
                   "Row Text ACI value = " (itoa (vla-get-ColorIndex colRowNew)) "\n"
                   "Background None = " (if (= colNoneNew :vlax-true) "True" "False")))
    (vla-SetBackgroundColor2 tableStyle "Title" colCurrent)
    (vla-SetColor2 tableStyle "Data" colRowCurrent)
    (vla-SetBackgroundColorNone tableStyle acHeaderRow colNoneCurrent)
    (alert "Reset the table style back to its original values.")
GMT+8, 2026-11-16 04:26
