SectionSolid 方法 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 833| 评论: 0|原作者: admin|来自: AutoCAD
创建一个区域,该区域表示由三个点定义的平面和实体的交点。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
RetVal = object.SectionSolid(Point1, Point2, Point3)
类型: 3DSolid
此方法应用到的对象。
第1点
访问:仅输入
类型:变体(双打的三元素阵列)
指定第一个点的 3D WCS 坐标。
第2点
访问:仅输入
类型:变体(双打的三元素阵列)
指定第二个点的 3D WCS 坐标。
第3点
访问:仅输入
类型:变体(双打的三元素阵列)
指定第三个点的 3D WCS 坐标。
返回值 (RetVal)
类型: 区域
生成的部分作为区域。
Sub Example_SectionSolid()
    ' This example creates a box in model space.
    ' It then sections the box based on a plane
    ' defined by three points. The section is returned
    ' as a region.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Define the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Define the section plane with three points
    Dim sectionPt1(0 To 2) As Double
    Dim sectionPt2(0 To 2) As Double
    Dim sectionPt3(0 To 2) As Double
    sectionPt1(0) = 1.5: sectionPt1(1) = 7.5: sectionPt1(2) = 0
    sectionPt2(0) = 1.5: sectionPt2(1) = 7.5: sectionPt2(2) = 10
    sectionPt3(0) = 8.5: sectionPt3(1) = 2.5: sectionPt3(2) = 10
    ' Section the box
    Dim sectionObj As AcadRegion
    Set sectionObj = boxObj.SectionSolid(sectionPt1, sectionPt2, sectionPt3)
    ' Change the viewing direction of the viewport
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_SectionSolid()
    ;; This example creates a box in model space.
    ;; It then sections the box based on a plane
    ;; defined by three points. The section is returned
    ;; as a region.
    ;; Define the box
    (setq center (vlax-3d-point 5 5 0)
          boxLength 5
	         boxWidth 7
	         boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
    ;; Define the section plane with three points
    (setq sectionPt1 (vlax-3d-point 1.5 7.5 0)
          sectionPt2 (vlax-3d-point 1.5 7.5 10)
          sectionPt3 (vlax-3d-point 8.5 2.5 10))
    ;; Section the box
    (setq sectionObj (vla-SectionSolid boxObj sectionPt1 sectionPt2 sectionPt3))
    ;; Change the viewing direction of the viewport
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-9-29 10:17
