ResetProfile 方法 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 868| 评论: 0|原作者: admin|来自: AutoCAD
将指定配置文件中的值重置为其默认值。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
object.ResetProfile Profile
类型:PreferencesProfiles
此方法应用到的对象。
轮廓
访问:仅输入
类型:字符串
要重置的配置文件。
返回值 (RetVal)
无返回值。
指定的配置文件必须是当前活动配置文件。若要将配置文件设置为当前活动配置文件,请使用该属性。ActiveProfile
Sub Example_ResetProfile()
    ' This example resets a profile to the default values.
    ' NOTE: A dummy profile name is used so that your existing
    ' profiles are not changed.
    Dim strProfileToReset As String
    Set preferences = ThisDrawing.Application.preferences
    ' Specify the profile to delete.
    strProfileToReset = "TestProfile"
    ' Delete the profile
    ' The call will fail if "TestProfile" does not exist
    On Error GoTo Error
    preferences.Profiles.ResetProfile strProfileToReset
    Exit Sub
Error:
    MsgBox "ResetProfile of " & strProfileToReset & " failed. " & Err.Description, , "ResetProfile Example"
(defun c:Example_ResetProfile()
    ;; This example resets a profile to the default values.
    ;; NOTE: A dummy profile name is used so that your existing
    ;; profiles are not changed.
    ;; Specify the profile to delete.
    (setq strProfileToReset "TestProfile")
    ;; Reset the profile
    ;; The call will fail if "TestProfile" does not exist
    (setq err (vl-catch-all-apply 'vla-ResetProfile (list (vla-get-Profiles preferences) strProfileToReset)))
    (if (= (type err) 'VL-CATCH-ALL-APPLY-ERROR)
        (alert (strcat "ResetProfile of " strProfileToReset " failed. "))
        (alert (strcat "We have just reset the profile " strProfileToReset))
GMT+8, 2026-11-16 00:42
