RemoveMenuFromMenuBar 方法 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 930| 评论: 0|原作者: admin|来自: AutoCAD
从 AutoCAD 菜单栏中删除从集合中指定的弹出菜单。
object.RemoveMenuFromMenuBar Index
类型:弹出菜单
此方法应用到的对象。
指数
访问:仅输入
类型:变体
要删除的弹出菜单的菜单栏中的索引。索引必须是整数或字符串。如果是整数,则索引必须介于 0 和 N-1 之间,其中 N 是菜单栏中的弹出菜单数。如果是字符串,则弹出菜单的名称必须包含菜单中显示的任何下划线。
返回值 (RetVal)
无返回值。
Sub Example_RemoveMenuFromMenuBar()
    ' This example creates a new menu called TestMenu and inserts a menu item
    ' into it. The menu is displayed on the menu bar, and then
    ' removed from the menu bar.
    Dim currMenuGroup As AcadMenuGroup
    Set currMenuGroup = ThisDrawing.Application.MenuGroups.Item(0)
    ' Create the new menu
    Dim newMenu As AcadPopupMenu
    Set newMenu = currMenuGroup.Menus.Add("TestMenu3")
    ' Add a menu item to the new menu
    Dim newMenuItem As AcadPopupMenuItem
    Dim openMacro As String
    ' Assign the macro string the VB equivalent of "ESC ESC _open "
    openMacro = Chr(3) & Chr(3) & Chr(95) & "open" & Chr(32)
    Set newMenuItem = newMenu.AddMenuItem(newMenu.Count + 1, "Open", openMacro)
    ' Display the menu on the menu bar
    newMenu.InsertInMenuBar ThisDrawing.Application.MenuBar.Count + 1
    GoSub QUERYMENU
    ' Remove the menu from the menu bar
    currMenuGroup.Menus.RemoveMenuFromMenuBar "TestMenu3"
    GoSub QUERYMENU
    Exit Sub
QUERYMENU:
    If newMenu.OnMenuBar Then
        MsgBox "The menu called " & newMenu.Name & " is on the menu bar."
    Else
        MsgBox "The menu called " & newMenu.Name & " is not on the menu bar."
    End If
    Return
(defun c:Example_RemoveMenuFromMenuBar()
    ;; This example creates a new menu called TestMenu and inserts a menu item
    ;; into it. The menu is displayed on the menu bar, and then
    ;; removed from the menu bar.
    (setq currMenuGroup (vla-Item (vla-get-MenuGroups acadObj) 0))
    ;; Create the new menu
    (setq newMenu (vla-Add (vla-get-Menus currMenuGroup) "TestMenu"))
    ;; Add a menu item to the new menu
    ;; Assign the macro string the VB equivalent of "ESC ESC _open "
    (setq openMacro (strcat (Chr 3) (Chr 3) (Chr 95) "open" (Chr 32)))
    (setq newMenuItem (vla-AddMenuItem newMenu (1+ (vla-get-Count newMenu)) "Open" openMacro))
    ;; Display the menu on the menu bar
    (vla-InsertInMenuBar newMenu (1+ (vla-get-Count (vla-get-MenuBar acadObj))))
    (if (= (vla-get-OnMenuBar newMenu) :vlax-true)
        (alert (strcat "The menu called " (vla-get-Name newMenu) " is on the menu bar."))
        (alert (strcat "The menu called " (vla-get-Name newMenu) " is not on the menu bar."))
    ;; Remove the menu from the menu bar
    (vla-RemoveMenuFromMenuBar (vla-get-Menus currMenuGroup) "TestMenu")
GMT+8, 2026-11-16 02:10
