RealToString 方法 (ActiveX)
将实数(双精度)值转换为字符串。 支持的平台:仅限 Windows 签名VBA: RetVal = object.RealToString(Value, Unit, Precision)
返回值 (RetVal)类型:字符串 格式正确的字符串的值。 言论没有其他评论。 例子VBA: Sub Example_RealToString()
' This example converts values in a given format to their string equivalents.
Dim unit As Long
Dim valueAsStr As String
Dim precision As Integer
Dim valueAsReal As Double
precision = 6
' Convert a real value 17.5 using Scientific mode to a String
unit = acScientific
valueAsStr = ThisDrawing.Utility.RealToString(17.5, unit, precision)
MsgBox "17.5 in scientific format is " & valueAsStr, , "RealToString Example"
' Convert a real value 17.5 using Decimal mode to a String
unit = acDecimal
MsgBox "17.5 in decimal format is " & valueAsStr, , "RealToString Example"
' Convert a real value 17.5 using Engineering mode to a String
unit = acEngineering
MsgBox "17.5 in engineering format is " & valueAsStr, , "RealToString Example"
' Convert a real value 17.5 using Architectural mode to a String
unit = acArchitectural
MsgBox "17.5 in architectural format is " & valueAsStr, , "RealToString Example"
' Converts a real value 17.5 using fractional mode to a String
unit = acFractional
MsgBox "17.5 in fractional format is " & valueAsStr, , "RealToString Example"
可视化 LISP: (vl-load-com)
(defun c:Example_RealToString()
;; This example converts values in a given format to their string equivalents.
(setq precision 6)
;; Convert a real value 17.5 using Scientific mode to a String
(setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acScientific precision))
(alert (strcat "17.5 in scientific format is " valueAsStr))
;; Convert a real value 17.5 using Decimal mode to a String
(setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acDecimal precision))
(alert (strcat "17.5 in decimal format is " valueAsStr))
;; Convert a real value 17.5 using Engineering mode to a String
(setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acEngineering precision))
(alert (strcat "17.5 in engineering format is " valueAsStr))
;; Convert a real value 17.5 using Architectural mode to a String
(setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acArchitectural precision))
(alert (strcat "17.5 in architectural format is " valueAsStr))
;; Converts a real value 17.5 using fractional mode to a String
(setq valueAsStr (vla-RealToString (vla-get-Utility doc) 17.5 acFractional precision))
(alert (strcat "17.5 in fractional format is " valueAsStr))
GMT+8, 2026-11-16 02:55
