Move 方法 (ActiveX)
2024-5-18 19:20| 发布者: admin| 查看: 1054| 评论: 0|原作者: admin|来自: AutoCAD
Move 方法 (ActiveX)
沿矢量移动对象。
object.Move Point1, Point2
类型:所有绘图对象、AttributeReference、尺寸
此方法应用到的对象。
第1点
访问:仅输入
类型:变体(双打的三元素阵列)
指定移动矢量的第一个点的 3D WCS 坐标。
第2点
访问:仅输入
类型:变体(双打的三元素阵列)
指定移动矢量的第二个点的 3D WCS 坐标。
返回值 (RetVal)
无返回值。
您指定的两个点定义了一个位移向量,指示给定对象要移动多远以及移动方向。
给定对象,并指示两个点
移动的对象
Sub Example_Move()
    ' This example creates a circle and then performs
    ' a move on that circle.
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2#: center(1) = 2#: center(2) = 0#
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(center, radius)
    ZoomAll
    ' Define the points that make up the move vector
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    point1(0) = 0: point1(1) = 0: point1(2) = 0
    point2(0) = 2: point2(1) = 0: point2(2) = 0
    MsgBox "Move the circle 2 units in the X direction.", , "Move Example"
    ' Move the circle
    circleObj.Move point1, point2
    ZoomAll
    MsgBox "Move completed.", , "Move Example"
(defun c:Example_Move()
    ;; This example creates a circle and then performs
    ;; a move on that circle.
    ;; Create the circle
    (setq center (vlax-3d-point 2 2 0)
          radius 0.5)
    (setq circleObj (vla-AddCircle modelSpace center radius))
    (vla-ZoomAll acadObj)
    ;; Define the points that make up the move vector
    (setq point1 (vlax-3d-point 0 0 0)
          point2 (vlax-3d-point 2 0 0))
    (alert "Move the circle 2 units in the X direction.")
    ;; Move the circle
    (vla-Move circleObj point1 point2)
    (alert "Move completed.")
GMT+8, 2026-11-16 03:59
