GetXRecordData 方法 (ActiveX)
获取与字典关联的扩展记录数据 (XRecordData)。 支持的平台:仅限 Windows 签名VBA: object.GetXRecordData XRecordDataType, XRecordDataValue
返回值 (RetVal)无返回值。 言论XRecord对象用于存储和管理任意数据。此对象在概念上类似于 XData,但不受大小或顺序的限制。 与XData不同,使用值均低于1000的标准AutoCAD组代码。支持所有标准 AutoCAD 组代码。这意味着,除了所有常用的数据类型之外,an 还能够存储对象 ID,从而允许拥有其他对象,包括其他 .XRecordsXRecordXRecordsXRecords 以下组代码是所有对象通用的:XRecord
例子VBA: Sub Example_SetXRecordData()
' This example creates a new XRecord if one doesn't exist,
' appends data to the XRecord, and reads it back. To see data being added,
' run the example more than once.
Dim TrackingDictionary As AcadDictionary, TrackingXRecord As AcadXRecord
Dim XRecordDataType As Variant, XRecordData As Variant
Dim ArraySize As Long, iCount As Long
Dim DataType As Integer, Data As String, msg As String
' Unique identifiers to distinguish our XRecordData from other XRecordData
Const TYPE_STRING = 1
Const TAG_DICTIONARY_NAME = "ObjectTrackerDictionary"
Const TAG_XRECORD_NAME = "ObjectTrackerXRecord"
' Connect to the dictionary in which the XRecord is stored
On Error GoTo CREATE
Set TrackingDictionary = ThisDrawing.Dictionaries(TAG_DICTIONARY_NAME)
Set TrackingXRecord = TrackingDictionary.GetObject(TAG_XRECORD_NAME)
On Error GoTo 0
' Get current XRecordData
TrackingXRecord.GetXRecordData XRecordDataType, XRecordData
' If there is no array already, create one
If VarType(XRecordDataType) And vbArray = vbArray Then
ArraySize = UBound(XRecordDataType) + 1 ' Get the size of the data elements returned
ArraySize = ArraySize + 1 ' Increase to hold new data
ReDim Preserve XRecordDataType(0 To ArraySize)
ReDim Preserve XRecordData(0 To ArraySize)
Else
ArraySize = 0
ReDim XRecordDataType(0 To ArraySize) As Integer
ReDim XRecordData(0 To ArraySize) As Variant
End If
' Append new XRecord Data
' For this sample, we only append the current time to the XRecord
XRecordDataType(ArraySize) = TYPE_STRING: XRecordData(ArraySize) = CStr(Now)
TrackingXRecord.SetXRecordData XRecordDataType, XRecordData
' Read back all XRecordData entries
' Retrieve and display stored XRecordData
For iCount = 0 To ArraySize
' Get information for this element
DataType = XRecordDataType(iCount)
Data = XRecordData(iCount)
If DataType = TYPE_STRING Then
msg = msg & Data & vbCrLf
End If
Next
MsgBox "The data in the XRecord is: " & vbCrLf & vbCrLf & msg, vbInformation
Exit Sub
CREATE:
' Create the objects that hold the XRecordData
If TrackingDictionary Is Nothing Then ' Make sure the tracking object is there
Set TrackingDictionary = ThisDrawing.Dictionaries.Add(TAG_DICTIONARY_NAME)
Set TrackingXRecord = TrackingDictionary.AddXRecord(TAG_XRECORD_NAME)
End If
Resume
可视化 LISP: (vl-load-com)
(defun c:Example_SetXRecordData()
;; This example creates a new XRecord if one doesn't exist,
;; appends data to the XRecord, and then reads it back. To see data being added,
;; run the example more than once.
;; Unique identifiers to distinguish this XRecordData from other XRecordData
(setq TYPE_STRING 1
TAG_DICTIONARY_NAME "ObjectTrackerDictionary"
TAG_XRECORD_NAME "ObjectTrackerXRecord")
;; Connect to the dictionary in which to store the XRecord
(setq TrackingDictionary (vl-catch-all-apply 'vla-Item (list dictionaries TAG_DICTIONARY_NAME)))
(if (= (type TrackingDictionary) 'VLA-OBJECT)
(setq TrackingXRecord (vl-catch-all-apply 'vla-GetObject (list TrackingDictionary TAG_XRECORD_NAME)))
(progn
;; Create the objects that hold this XRecordData
(setq TrackingDictionary (vla-Add dictionaries TAG_DICTIONARY_NAME))
;; Add a new XRecord, but only if using AutoCAD
(if (/= (strcase (getvar "PROGRAM") T) "acadlt")
(setq TrackingXRecord (vla-AddXRecord TrackingDictionary TAG_XRECORD_NAME))
;; Get current XRecordData
(if (= (type TrackingXRecord) 'VLA-OBJECT)
(progn
(vla-GetXRecordData TrackingXRecord 'temp-XRecordDataType 'temp-XRecordData)
;; If there is no array yet then create one
(setq ArraySize 0)
(if (/= temp-XRecordDataType nil)
(progn
(setq ArraySize (vlax-safearray-get-u-bound temp-XRecordDataType 1))
(setq XRecordDataType (vlax-make-safearray vlax-vbInteger (cons 0 (1+ ArraySize))))
(setq XRecordData (vlax-make-safearray vlax-vbVariant (cons 0 (1+ ArraySize))))
(setq iCount 0)
(while (>= ArraySize iCount)
;; Get information for this element
(setq DataType (vlax-safearray-get-element temp-XRecordDataType iCount))
(setq Data (vlax-variant-value (vlax-safearray-get-element temp-XRecordData iCount)))
(vlax-safearray-put-element XRecordDataType iCount DataType)
(vlax-safearray-put-element XRecordData iCount Data)
(setq iCount (1+ iCount))
(progn
(setq XRecordDataType (vlax-make-safearray vlax-vbInteger '(0 . 0)))
(setq XRecordData (vlax-make-safearray vlax-vbVariant '(0 . 0)))
;; Append new XRecord Data, but only if using AutoCAD
(progn
;; For this sample we only append the current time to the XRecord
(vlax-safearray-put-element XRecordDataType ArraySize TYPE_STRING)
(setq cdate (rtos (vlax-variant-value (vla-GetVariable doc "CDATE")) 2 6))
(vlax-safearray-put-element XRecordData ArraySize (strcat (substr cdate 5 2) "/"
(substr cdate 7 2) "/"
(substr cdate 1 4) "-"
(substr cdate 10 2) ":"
(substr cdate 12 2) ":"
(substr cdate 14)))
(vla-SetXRecordData TrackingXRecord XRecordDataType XRecordData)
;; Read back all XRecordData entries
(vla-GetXRecordData TrackingXRecord 'XRecordDataType 'XRecordData)
(setq ArraySize (vlax-safearray-get-u-bound XRecordDataType 1))
;; Display the stored XRecord Data
(setq iCount 0
msg "")
(setq DataType (vlax-safearray-get-element XRecordDataType iCount))
(setq Data (vlax-variant-value (vlax-safearray-get-element XRecordData iCount)))
(if (= DataType TYPE_STRING)
(setq msg (strcat msg Data "\n"))
(alert (strcat "The data in the XRecord is: \n\n" msg))
(alert "XRecord was not added or found.\nXRecords can only be added using the API with AutoCAD.")
GMT+8, 2026-11-16 04:07
