GetInvisibleEdge 方法 (ActiveX)
获取给定索引处 3DFace 对象边缘的可见性设置。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetInvisibleEdge(Index)
返回值 (RetVal)类型:布尔
言论没有其他评论。 例子VBA: Sub Example_GetInvisibleEdge()
' This example creates a 3D face in model space.
' It then toggles the visibility of the first edge.
Dim faceObj As Acad3DFace
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim point3(0 To 2) As Double
Dim point4(0 To 2) As Double
' Define the four coordinates of the face
point1(0) = 1#: point1(1) = 1#: point1(2) = 0#
point2(0) = 5#: point2(1) = 1#: point2(2) = 1#
point3(0) = 5#: point3(1) = 5#: point3(2) = 1#
point4(0) = 1#: point4(1) = 10#: point4(2) = 0#
' Create the 3DFace object in model space
Set faceObj = ThisDrawing.ModelSpace.Add3DFace(point1, point2, point3, point4)
ZoomAll
' Find the current visibility status of the first edge of the face
Dim visStatus As Boolean
visStatus = faceObj.GetInvisibleEdge(0)
MsgBox "The first face is currently " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
' Toggle the visibility of the first edge of the face
faceObj.SetInvisibleEdge 0, Not (visStatus)
ThisDrawing.Regen False
MsgBox "The first face is now " & IIf(faceObj.GetInvisibleEdge(0), "visible.", "invisible."), , "GetInvisibleEdge Example"
可视化 LISP: (vl-load-com)
(defun c:Example_GetInvisibleEdge()
;; This example creates a 3D face in model space.
;; It then toggles the visibility of the first edge.
;; Define the four coordinates of the face
(setq point1 (vlax-3d-point 1 1 0)
point2 (vlax-3d-point 5 1 1)
point3 (vlax-3d-point 5 5 1)
point4 (vlax-3d-point 1 10 0))
;; Create the 3DFace object in model space
(setq faceObj (vla-Add3DFace modelSpace point1 point2 point3 point4))
(vla-ZoomAll acadObj)
;; Find the current visibility status of the first edge of the face
(setq visStatus (vla-GetInvisibleEdge faceObj 0))
(alert (strcat "The first face is currently " (if (= visStatus :vlax-true) "visible." "invisible.")))
;; Toggle the visibility of the first edge of the face
(vla-SetInvisibleEdge faceObj 0 (if (= visStatus :vlax-true) :vlax-false :vlax-true))
(vla-Regen doc :vlax-false)
(alert (strcat "The first face is now " (if (= (vla-GetInvisibleEdge faceObj 0) :vlax-true) "visible." "invisible.")))
GMT+8, 2026-11-16 04:37
