GetAlignment2 方法 (ActiveX)
获取单元格对齐方式。 支持的平台:仅限 Windows 签名VBA: RetVal = object.GetAlignment2(bstrCellStyle)
返回值 (RetVal)类型:枚举AcCellAlignment 用于单元格样式的对齐方式。
言论没有其他评论。 例子VBA: Sub Example_GetAlignment2()
' the style name and other attributes.
Dim dictObj As AcadDictionary
' Create the custom TableStyle object in the dictionary
Dim keyName As String
Dim className As String
Dim customObj As AcadTableStyle
keyName = "NewStyle"
className = "AcDbTableStyle"
Set customObj = dictObj.AddObject(keyName, className)
customObj.Name = "NewStyle"
customObj.Description = "New Style for My Tables"
customObj.FlowDirection = acTableBottomToTop
customObj.HorzCellMargin = 0.22
customObj.BitFlags = 1
customObj.SetTextHeight acTitleRow, 1.3
customObj.SetTextHeight acHeaderRow, 1
customObj.SetTextHeight acDataRow, 1
customObj.SetTextStyle acTitleRow, "Standard"
customObj.SetTextStyle acHeaderRow, "Standard"
customObj.SetTextStyle acDataRow, "Standard"
Dim col As AcadAcCmColor
Set col = customObj.GetBackgroundColor(acTitleRow)
col.SetRGB 12, 23, 45
customObj.SetBackgroundColor acTitleRow, col
customObj.SetGridVisibility acHorzInside + acHorzTop, acTitleRow, True
customObj.SetGridVisibility acHorzInside + acHorzTop, acHeaderRow, True
customObj.SetGridVisibility acHorzInside + acHorzTop, acDataRow, True
customObj.SetAlignment2 "Title", acBottomRight
customObj.SetAlignment2 "Header", acBottomCenter
customObj.SetAlignment2 "Data", acBottomRight
col.SetRGB 244, 0, 0
customObj.SetGridColor acHorzInside + acHorzTop, acDataRow, col
MsgBox "Table Style Name = " & customObj.Name & vbCrLf & _
"Style Description = " & customObj.Description & vbCrLf & _
"Flow Direction = " & customObj.FlowDirection & vbCrLf & _
"Horzontal Cell Margin = " & customObj.HorzCellMargin & vbCrLf & _
"Bit Flags = " & customObj.BitFlags & vbCrLf & _
"Title Row Text Height = " & customObj.GetTextHeight(acTitleRow) & vbCrLf & _
"Title Row Text Style = " & customObj.GetTextStyle(acTitleRow) & vbCrLf & _
"Grid Visibility for HorizontalBottom TitleRow = " & customObj.GetGridVisibility(acHorzBottom, acTitleRow) & vbCrLf & _
"Title Row Alignment = " & customObj.GetAlignment2("Title") & vbCrLf & _
"Header Suppression = " & customObj.HeaderSuppressed
可视化 LISP: (vl-load-com)
(defun c:Example_GetAlignment2()
;; the style name and other attributes.
doc (vla-get-ActiveDocument acadObj))
(setq dictionaries (vla-get-Dictionaries doc)
dictObj (vla-Item dictionaries "acad_tablestyle"))
;; Create the custom TableStyle object in the dictionary
(setq keyName "NewStyle"
className "AcDbTableStyle")
(setq customObj (vla-AddObject dictObj keyName className))
(vla-put-Name customObj "NewStyle")
(vla-put-Description customObj "New Style for My Tables")
(vla-put-FlowDirection customObj acTableBottomToTop)
(vla-put-HorzCellMargin customObj 0.22)
(vla-put-BitFlags customObj 1)
(vla-SetTextHeight customObj acTitleRow 1.3)
(vla-SetTextHeight customObj acHeaderRow 1)
(vla-SetTextHeight customObj acDataRow 1)
(vla-SetTextStyle customObj acTitleRow "Standard")
(vla-SetTextStyle customObj acHeaderRow "Standard")
(vla-SetTextStyle customObj acDataRow "Standard")
(setq col (vla-GetBackgroundColor customObj acTitleRow))
(vla-SetRGB col 12 23 45)
(vla-SetBackgroundColor customObj acTitleRow col)
(vla-SetGridVisibility customObj (+ acHorzInside acHorzTop) acTitleRow :vlax-true)
(vla-SetGridVisibility customObj (+ acHorzInside acHorzTop) acHeaderRow :vlax-true)
(vla-SetGridVisibility customObj (+ acHorzInside acHorzTop) acDataRow :vlax-true)
(vla-SetAlignment2 customObj "Title" acBottomRight)
(vla-SetAlignment2 customObj "Header" acBottomCenter)
(vla-SetAlignment2 customObj "Data" acBottomRight)
(vla-SetRGB col 244 0 0)
(vla-SetGridColor customObj (+ acHorzTop acHorzInside) acDataRow col)
(alert (strcat "Table Style Name = " (vla-get-Name customObj)
"\nStyle Description = " (vla-get-Description customObj)
"\nFlow Direction = " (itoa (vla-get-FlowDirection customObj))
"\nHorzontal Cell Margin = " (rtos (vla-get-HorzCellMargin customObj) 2)
"\nBit Flags = " (itoa (vla-get-BitFlags customObj))
"\nTitle Row Text Height = " (rtos (vla-GetTextHeight customObj acTitleRow) 2)
"\nTitle Row Text Style = " (vla-GetTextStyle customObj acTitleRow)
"\nGrid Visibility for HorizontalBottom TitleRow = " (if (= (vla-GetGridVisibility customObj acHorzBottom acTitleRow) :vlax-true) "True" "False")
"\nTitle Row Alignment = " (itoa (vla-GetAlignment2 customObj "Title"))
"\nHeader Suppression = " (if (= (vla-get-HeaderSuppressed customObj) :vlax-true) "True" "False")
GMT+8, 2026-11-16 04:07
