DeleteProfile 方法 (ActiveX)
删除指定的配置文件。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 签名VBA: object.DeleteProfile ProfileName
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_DeleteProfile()
' This example deletes a profile.
Dim strProfileToDelete As String
Set preferences = ThisDrawing.Application.preferences
' Specify the profile to delete.
strProfileToDelete = "TestProfile"
' Delete the profile
' The call will fail if "TestProfile" does not exist or
' if "TestProfile" is the current profile.
On Error GoTo Error
preferences.Profiles.DeleteProfile strProfileToDelete
Exit Sub
Error:
MsgBox "DeleteProfile of " & strProfileToDelete & " failed. " & Err.Description, , "DeleteProfile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DeleteProfile()
;; This example deletes a profile.
;; Specify the profile to delete.
(setq strProfileToDelete "TestProfile")
(vla-CopyProfile (vla-get-Profiles preferences) "<<Unnamed Profile>>" strProfileToDelete)
(alert (strcat "Profile " strProfileToDelete " created from <<Unnamed Profile>>."))
;; Delete the profile
;; The call will fail if "TestProfile" does not exist or
;; if "TestProfile" is the current profile.
(vla-DeleteProfile (vla-get-Profiles preferences) strProfileToDelete)
(alert (strcat "Profile " strProfileToDelete " deleted."))
GMT+8, 2026-11-16 04:22
