DeleteFitPoint 方法 (ActiveX)
删除样条曲线在给定索引处的拟合点。 支持的平台:仅限 Windows 签名VBA: object.DeleteFitPoint Index
返回值 (RetVal)无返回值。 言论AutoCAD 将移除拟合点,然后通过其余点重新调整样条曲线。样条中必须至少有三个拟合点,此方法才能成功。若要查看更改,请使用 or 方法。UpdateRegen 例子VBA: Sub Example_DeleteFitPoint()
' This example creates a spline object in model space.
' It then deletes a fit point from the spline.
' Create the spline
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
Set splineObj = ThisDrawing.ModelSpace.AddSpline(fitPoints, startTan, endTan)
ZoomAll
MsgBox "Delete the first fit point", , "DeleteFitPoint Example"
' Delete the first fit point in the spline
splineObj.DeleteFitPoint 0
ThisDrawing.Regen True
MsgBox "A fit point has been deleted at Index: 0", , "DeleteFitPoint Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DeleteFitPoint()
;; This example creates a spline object in model space.
;; It then deletes a fit point from the spline.
;; Create the spline
(setq startTan (vlax-3d-point 0.5 0.5 0)
endTan (vlax-3d-point 0.5 0.5 0)
fitPoints (vlax-make-safearray vlax-vbDouble '(0 . 8)))
(vlax-safearray-fill fitPoints '(1 1 0
5 5 0
10 0 0
(setq splineObj (vla-AddSpline modelSpace fitPoints startTan endTan))
(vla-ZoomAll acadObj)
(alert "Delete the first fit point.")
;; Delete the first fit point in the spline
(vla-DeleteFitPoint splineObj 0)
(vla-Regen doc :vlax-true)
(alert "A fit point has been deleted at Index: 0")
GMT+8, 2026-10-25 14:20
