CopyProfile 方法 (ActiveX)
复制指定的配置文件。 支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持 签名VBA: object.CopyProfile oldProfileName, newProfileName
返回值 (RetVal)无返回值。 言论没有其他评论。 例子VBA: Sub Example_CopyProfile()
' This example copies an existing profile.
' You can see the new profile under Options/Profiles
' *Note: This example relies on the default profile "<<Unnamed Profile>>".
' If this profile has already been renamed or removed, be sure to change the
' name of the SourceProfile to one that currently exists.
Dim ACADPref As AcadPreferencesProfiles
Dim SourceProfile As String, DestinationProfile As String
' Use the PreferencesProfiles object
Set ACADPref = ThisDrawing.Application.Preferences.Profiles
' Copy the default profile
On Error GoTo ERRORTRAP
SourceProfile = "<<Unnamed Profile>>"
DestinationProfile = "NEW_PROFILE"
ACADPref.CopyProfile SourceProfile, DestinationProfile
MsgBox "We have just copied the existing profile " & SourceProfile & " to " & DestinationProfile
Exit Sub
ERRORTRAP:
If Err.Description <> "" Then
MsgBox "The default profile '" & SourceProfile & "' cannot be found, please use a different source profile."
End If
可视化 LISP: (vl-load-com)
(defun c:Example_CopyProfile()
;; This example copies an existing profile.
;; You can see the new profile under Options/Profiles
;; *Note: This example relies on the default profile "<<Unnamed Profile>>".
;; If this profile has already been renamed or removed, be sure to change the
;; name of the SourceProfile to one that currently exists.
;; Use the PreferencesProfiles object
(setq ACADPref (vla-get-Profiles preferences))
(setq SourceProfile "<<Unnamed Profile>>"
DestinationProfile "NEW_PROFILE")
(vla-CopyProfile ACADPref SourceProfile DestinationProfile)
(alert (strcat "We have just copied the existing profile " SourceProfile " to " DestinationProfile))
GMT+8, 2026-11-16 02:10
