AddCylinder 方法 (ActiveX)
2024-5-18 19:19| 发布者: admin| 查看: 838| 评论: 0|原作者: admin|来自: AutoCAD
创建一个 3D 实体圆柱体,其底位于 WCS 的 XY 平面上。
支持的平台:仅限 AutoCAD for Windows;AutoCAD LT for Windows 不支持
RetVal = object.AddCylinder(Center, Radius, Height)
类型:块、模型空间、纸空间
此方法应用到的对象。
中心
访问:仅输入
类型:变体(双打的三元素阵列)
指定边界框中心的 3D WCS 坐标。
半径
访问:仅输入
类型:双
圆柱体半径。必须为正数。
高度
访问:仅输入
类型:双
气缸高度。必须为正数。
返回值 (RetVal)
类型: 3DSolid
作为新创建的圆柱体的对象。3DSolid
Sub Example_AddCylinder()
    ' This example creates a cylinder in model space.
    Dim cylinderObj As Acad3DSolid
    Dim radius As Double
    Dim center(0 To 2) As Double
    Dim height As Double
    ' Define the cylinder
    center(0) = 0#: center(1) = 0#: center(2) = 0#
    radius = 5#
    height = 20#
    ' Create the Cylinder (3DSolid) object in model space
    Set cylinderObj = ThisDrawing.ModelSpace.AddCylinder(center, radius, height)
    ' Change the viewing direction of the viewport to better see the cylinder
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
(defun c:Example_AddCylinder()
    ;; This example creates a cylinder in model space.
    ;; Define the cylinder
    (setq center (vlax-3d-point 0 0 0)
          cylRadius 5
	         cylHeight 20)
    ;; Create the Cylinder (3DSolid) object in model space
    (setq cylinderObj (vla-AddCylinder modelSpace center cylRadius cylHeight))
    ;; Change the viewing direction of the viewport to better see the cylinder
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
GMT+8, 2026-11-16 01:59
