关于分配和检索扩展数据 (VBA/ActiveX)
2024-5-18 19:19| 发布者: admin| 查看: 1067| 评论: 0|原作者: admin|来自: AutoCAD
可以使用扩展数据 (xdata) 作为将信息与图形中的对象链接的方法。
将 xdata 分配给选择集中的所有对象
本示例提示用户从图形中选取对象。所选对象将放置到选择集中,并且指定的 xdata 将附加到该选择集中的所有对象。
Sub Ch10_AttachXDataToSelectionSetObjects()
 ' Create the selection set
 Dim sset As Object
 Set sset = ThisDrawing.SelectionSets.Add("SS1")
 ' Prompt the user to select objects
 sset.SelectOnScreen
 ' Define the xdata
 Dim appName As String, xdataStr As String
 appName = "MY_APP"
 xdataStr = "This is some xdata"
 Dim xdataType(0 To 1) As Integer
 Dim xdata(0 To 1) As Variant
 ' Define the values for each array
 '1001 indicates the appName
 xdataType(0) = 1001
 xdata(0) = appName
 '1000 indicates a string value
 xdataType(1) = 1000
 xdata(1) = xdataStr
 ' Loop through all entities in the selection
 ' set and assign the xdata to each entity
 Dim ent As Object
 For Each ent In sset
 ent.SetXData xdataType, xdata
 Next ent
查看选择集中所有对象的 xdata
此示例显示与上一个示例一起附加的 xdata。如果附加字符串以外的 xdata(类型 1000),则需要修改此代码。
Sub Ch10_ViewXData()
 ' Find the selection created in previous example
 Dim sset As Object
 Set sset = ThisDrawing.SelectionSets.Item("SS1")
 ' Define the xdata variables to hold xdata information
 Dim xdataType As Variant
 Dim xdata As Variant
 Dim xd As Variant
 'Define index counter
 Dim xdi As Integer
 xdi = 0
 ' Loop through the objects in the selection set
 ' and retrieve the xdata for the object
 Dim msgstr As String
 Dim ent As AcadEntity
 appName = "MY_APP"
 msgstr = ""
 xdi = 0
 ' Retrieve the appName xdata type and value
 ent.GetXData appName, xdataType, xdata
 ' If the xdataType variable is not initialized, there
 ' was no appName xdata to retrieve for that entity
 If VarType(xdataType) <> vbEmpty Then
 For Each xd In xdata
 msgstr = msgstr & vbCrLf & xdataType(xdi) _
 & ": " & xd
 xdi = xdi + 1
 Next xd
 End If
 ' If the msgstr variable is NULL, there was no xdata
 If msgstr = "" Then msgstr = vbCrLf & "NONE"
 MsgBox appName & " xdata on " & ent.ObjectName & _
 ":" & vbCrLf & msgstr
 Next ent
GMT+8, 2026-11-16 04:45
