关于分解对象 (VBA/ActiveX)
2024-5-18 19:19| 发布者: admin| 查看: 1001| 评论: 0|原作者: admin|来自: AutoCAD
分解对象将对象从单个对象转换为其组成部分,但没有可见效果。
例如,分解从 3D 多边形、折线、多边形网格和区域形成简单的直线和圆弧。它将块引用替换为组成块的简单对象的副本。
分解折线
本示例创建一个轻量级折线对象。然后,它将折线分解为单独的对象。然后,该示例循环访问生成的对象,并显示一个消息框,其中包含每个对象的名称及其在分解对象列表中的索引。
Sub Ch4_ExplodePolyline()
  Dim points(0 To 11) As Double
  ' Define the 2D polyline points
  points(0) = 1: points(1) = 1
  points(2) = 1: points(3) = 2
  points(4) = 2: points(5) = 2
  points(6) = 3: points(7) = 2
  points(8) = 4: points(9) = 4
  points(10) = 4: points(11) = 1
  ' Create a light weight Polyline object
  Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
  ' Set the bulge on one segment to vary the
  ' type of objects in the polyline
  plineObj.SetBulge 3, -0.5
  plineObj.Update
  ' Explode the polyline
  Dim explodedObjects As Variant
  explodedObjects = plineObj.Explode
  ' Loop through the exploded objects
  ' and display a message box with
  ' the type of each object
  Dim I As Integer
  For I = 0 To UBound(explodedObjects)
    explodedObjects(I).Update
    MsgBox "Exploded Object " & I & ": " & explodedObjects(I).ObjectName
  Next
GMT+8, 2026-11-17 01:25
