关于请求积分 (ActiveX)
2024-5-18 19:18| 发布者: admin| 查看: 960| 评论: 0|原作者: admin|来自: AutoCAD
关于请求积分 (ActiveX)
该方法在 AutoCAD 命令提示符下提示用户指定点。GetPoint
此方法接受两个参数,可选的 from point 和提示字符串。如果提供了起始点,AutoCAD 将从该点绘制一条橡皮筋线。若要控制用户输入,可以在此方法之前调用该方法。InitializeUserInput
获取用户选择的点
下面的示例提示用户输入两个点,然后使用这些点作为起点和终结点绘制一条线。
AutoLISP
(defun c:Ch3_GetPointsFromUser()
          doc (vla-get-ActiveDocument acadObj)
          moSpace (vla-get-ModelSpace doc)
          utilityObj (vla-get-Utility doc))
    (setq prompt1 "\nSpecify start point of line: "
          prompt2 "\nSpecify end point of line: ")
    ;; Get the first point without entering a base point
    (setq startPnt (vla-GetPoint utilityObj nil prompt1))
    ;; Use the point entered above as the base point
    (setq endPnt (vla-GetPoint utilityObj startPnt prompt2))
    ;; Create a line using the two points entered
    (vla-AddLine moSpace startPnt endPnt)
    (vla-ZoomAll acadObj)
VBA(仅限 AutoCAD)
Sub Ch3_GetPointsFromUser()
  Dim startPnt As Variant
  Dim endPnt As Variant
  Dim prompt1 As String
  Dim prompt2 As String
  prompt1 = vbCrLf & "Specify start point of line: "
  prompt2 = vbCrLf & "Specify end point of line: "
  ' Get the first point without entering a base point
  startPnt = ThisDrawing.Utility.GetPoint(, prompt1)
  ' Use the point entered above as the base point
  endPnt = ThisDrawing.Utility.GetPoint(startPnt, prompt2)
  ' Create a line using the two points entered
  ThisDrawing.ModelSpace.AddLine startPnt, endPnt
GMT+8, 2026-11-16 00:32
