关于查询光线 (ActiveX)
2024-5-18 19:18| 发布者: admin| 查看: 943| 评论: 0|原作者: admin|来自: AutoCAD
关于查询光线 (ActiveX)
创建后,您可以查询射线以确定用于创建对象的点。
该属性可用于获取光线的第一个点。虽然用于创建光线的第二个点不与对象一起存储,但可以使用该属性来获取光线的方向向量。BasePointDirectionVector
添加、查询和编辑 Ray 对象
下面的示例代码使用两点 (5, 0, 0) 和 (1, 1, 0) 创建一个对象。然后,它查询当前基点和方向向量,并在消息框中显示结果。然后更改方向向量,查询并显示基点和新方向向量。Ray
AutoLISP
(defun c:Ch3_EditRay()
          doc (vla-get-ActiveDocument acadObj)
          moSpace (vla-get-ModelSpace doc))
    ;; Define the ray
    (setq basePoint (vlax-3d-point 3 3 0)
          secondPoint (vlax-3d-point 4 4 0))
    ;; Creates a Ray object in model space
    (setq rayObj (vla-AddRay moSpace basePoint secondPoint))
    (vla-ZoomAll acadObj)
    ;; Find the current status of the Ray
    (setq LBPoint (vlax-safearray->list (vlax-variant-value (vla-get-BasePoint rayObj)))
          LDirVector (vlax-safearray->list (vlax-variant-value (vla-get-DirectionVector rayObj))))
    (alert (strcat "The base point of the ray is: "
                   (rtos (nth 0 LBPoint) 2) ", "
                   (rtos (nth 1 LBPoint) 2) ", "
                   (rtos (nth 2 LBPoint) 2)
                   "\nThe directional vector for the ray is: "
                   (rtos (nth 0 LDirVector) 2) ", "
                   (rtos (nth 1 LDirVector) 2) ", "
                   (rtos (nth 2 LDirVector) 2)))
    ;; Change the directional vector for the ray
    (setq newVector (vlax-3d-point -1 1 0))
    (vla-put-DirectionVector rayObj newVector)
    (vla-Regen doc :vlax-false)
VBA(仅限 AutoCAD)
Sub Ch3_EditRay()
  Dim rayObj As AcadRay
  Dim basePoint(0 To 2) As Double
  Dim secondPoint(0 To 2) As Double
  ' Define the ray
  basePoint(0) = 3#: basePoint(1) = 3#: basePoint(2) = 0#
  secondPoint(0) = 4#: secondPoint(1) = 4#: secondPoint(2) = 0#
  ' Creates a Ray object in model space
  Set rayObj = ThisDrawing.ModelSpace.AddRay(basePoint, secondPoint)
  ' Find the current status of the Ray
  MsgBox "The base point of the ray is: " & _
  rayObj.basePoint(0) & ", " & _
  rayObj.basePoint(1) & ", " & _
  rayObj.basePoint(2) & vbCrLf & _
  "The directional vector for the ray is: " & _
  rayObj.DirectionVector(0) & ", " & _
  rayObj.DirectionVector(1) & ", " & _
  rayObj.DirectionVector(2), , "Edit Ray"
  ' Change the directional vector for the ray
  Dim newVector(0 To 2) As Double
  newVector(0) = -1
  newVector(1) = 1
  newVector(2) = 0
  rayObj.DirectionVector = newVector
  ThisDrawing.Regen False
GMT+8, 2026-11-16 01:32
