关于解释变体数组 (ActiveX)
2024-5-18 19:18| 发布者: admin| 查看: 752| 评论: 0|原作者: admin|来自: AutoCAD
关于解释变体数组 (ActiveX)
从 AutoCAD ActiveX Automation 传回的阵列信息将作为变体传回。
如果您知道数组的数据类型,则可以简单地将变体作为数组进行访问。如果不知道变体中包含的数据类型,请使用 VBA 中的 or 函数或 AutoLISP 中的 、 和 函数。这些函数返回变体中的数据类型。如果需要循环访问数组,可以在 AutoLISP 中使用 VBA 语句或函数。VarTypeTypeNamevlax-variant-typevlax-variant-valuetypeFor Eachvlax-for
计算两点之间的距离
下面的代码演示如何计算用户输入的两点之间的距离。在此示例中,数据类型是已知的,因为所有坐标都是双精度坐标。3D 坐标是双精度的三元素数组,2D 坐标是双精度的双元素数组。
AutoLISP
(defun c:Ch2_CalculateDistance()
          doc (vla-get-ActiveDocument acadObj)
          utilObj (vla-get-Utility doc))
    ;; Get the points from the user
    (setq point1 (vlax-variant-value (vla-GetPoint utilObj nil "First point: "))
          point2 (vlax-variant-value (vla-GetPoint utilObj point1 "Second point: ")))
    ;; Calculate the distance between point1 and point2
    (setq X (- (vlax-safearray-get-element point1 0) (vlax-safearray-get-element point2 0))
          Y (- (vlax-safearray-get-element point1 1) (vlax-safearray-get-element point2 1))
          Z (- (vlax-safearray-get-element point1 2) (vlax-safearray-get-element point2 2))
          dist (sqrt (+ (expt (sqrt (+ (expt X 2)(expt Y 2))) 2) (expt Z 2))))
    ;; Display the resulting distance
    (alert (strcat "The distance between the points is: " (rtos dist 2)))
VBA(仅限 AutoCAD)
Sub Ch2_CalculateDistance()
    Dim point1 As Variant
    Dim point2 As Variant
    '' Get the points from the user
    point1 = ThisDrawing.Utility.GetPoint(, vbCrLf & "First point: ")
    point2 = ThisDrawing.Utility.GetPoint(point1, vbCrLf & "Second point: ")
    '' Calculate the distance between point1 and point2
    Dim x As Double, y As Double, z As Double
    Dim dist As Double
    x = point1(0) - point2(0)
    y = point1(1) - point2(1)
    z = point1(2) - point2(2)
    dist = Sqr((Sqr((x ^ 2) + (y ^ 2)) ^ 2) + (z ^ 2))
    '' Display the resulting distance
    MsgBox "The distance between the points is: " _
           & dist, , "Calculate Distance"
GMT+8, 2026-11-16 03:44
