AutoCAD 2013 API 历史记录参考 (ActiveX)
2024-5-18 19:18| 发布者: admin| 查看: 1108| 评论: 0|原作者: admin|来自: AutoCAD
对 AutoCAD 2013 和基于 AutoCAD 2013 的产品中的 ActiveX API 所做的添加和更改。
枚举
AcSaveAsType (Changed)
        ac2013_dwg = 60 (New)
        ac2013_dxf = 61 (New)
        ac2013_Template = 62 (New)
        acNative = 60 (Changed)
AcPointCloudColorType (Changed)
        acTrueColor = 0 (New)
        acByColor = 1 (New)
AcPointCloudIntensityStyle (New)
        acIntensityGrayscale = 0
        acIntensityRainbow = 1
        acIntensityRed = 2
        acIntensityGreen = 3
        acIntensityBlue = 4
        acIntensityEditableFlag = 5
类
IAcadEntity (Changed)
        EntityTransparency - Property (Moved from IAcadEntity2)
IAcad3DSolid (Changed)
        CheckInterference - Method (Added solid interfere parameter)
IAcadSpline (Changed)
        KnotParameterization - Property (Moved from IAcadSpline2)
        SplineFrame - Property (Moved from IAcadSpline2)
        SplineMethod - Property (Moved from IAcadSpline2)
        Degree2 - Property (Moved from IAcadSpline2)
        Closed2 - Property (Moved from IAcadSpline2)
IAcadHatch (Changed)
        BackgroundColor - Property (Moved from IAcadHatch2)
IAcadRasterImage (Changed)
        transparency - Property (Renamed, previously Transparency)
IAcadDynamicBlockReferenceProperty (Changed)
        show - Property (Renamed, previously Show)
IAcadSurface (Changed)
        WireframeType - Property (Moved from IAcadSurface2)
        MaintainAssociativity - Property (Moved from IAcadSurface2)
        ShowAssociativity - Property (Moved from IAcadSurface2)
        EdgeExtensionDistances - Property (Moved from IAcadSurface2)
        SurfTrimAssociativity - Property (Moved from IAcadSurface3)
IAcadLoftedSurface (Changed)
        StartSmoothMagnitude - Property (Moved from IAcadLoftedSurface2)
        EndSmoothMagnitude - Property (Moved from IAcadLoftedSurface2)
        StartSmoothContinuity - Property (Moved from IAcadLoftedSurface2)
        EndSmoothContinuity - Property (Moved from IAcadLoftedSurface2)
        Periodic - Property (Moved from IAcadLoftedSurface2)
IAcadPointCloud (Changed)
        ShowIntensity - Property (New)
        IntensityColorScheme - Property (New)
        Width - Property (New)
        Length - Property (New)
        Height - Property (New)
        Name - Property (New)
        Path - Property (New)
        ShowClipped - Property (New)
IAcadPreferencesFiles (Changed)
        ActiveInvProject - Property (New)
以下类已删除/与其父类合并:
IAcadEntity2 - Removed (Moved to IAcadEntity)
IAcadRasterImage2 - Removed (Moved to IAcadRasterImage)
IAcad3DFace2 - Removed (Moved to IAcad3DFace)
IAcad3DPolyline2 - Removed (Moved to IAcad3DPolyline)
IAcadRegion2 - Removed (Moved to IAcadRegion)
IAcad3DSolid2 - Removed (Moved to IAcad3DSolid)
IAcadArc2 - Removed (Moved to IAcadArc)
IAcadAttribute2 - Removed (Moved to IAcadAttribute)
IAcadBlockReference2 - Removed (Moved to IAcadBlockReference)
IAcadCircle2 - Removed (Moved to IAcadCircle)
IAcadEllipse2 - Removed (Moved to IAcadEllipse)
IAcadHatch2 - Removed (Moved to IAcadHatch)
IAcadLeader2 - Removed (Moved to IAcadLeader)
IAcadMLeader2 - Removed (Moved to IAcadMLeader)
IAcadLWPolyline2 - Removed (Moved to IAcadLWPolyline)
IAcadLine2 - Removed (Moved to IAcadLine)
IAcadMText2 - Removed (Moved to IAcadMText)
IAcadPoint2 - Removed (Moved to IAcadPoint)
IAcadPolyline2 - Removed (Moved to IAcadPolyline)
IAcadPolygonMesh2 - Removed (Moved to IAcadPolygonMesh)
IAcadRay2 - Removed (Moved to IAcadRay)
IAcadShape2 - Removed (Moved to IAcadShape)
IAcadSolid2 - Removed (Moved to IAcadSolid)
IAcadSpline2 - Removed (Moved to IAcadSpline)
IAcadText2 - Removed (Moved to IAcadText)
IAcadTolerance2 - Removed (Moved to IAcadTolerance)
IAcadTrace2 - Removed (Moved to IAcadTrace)
IAcadXline2 - Removed (Moved to IAcadXline)
IAcadPViewport2 - Removed (Moved to IAcadPViewport)
IAcadPolyfaceMesh2 - Removed (Moved to IAcadPolyfaceMesh)
IAcadMLine2 - Removed (Moved to IAcadMLine)
IAcadExternalReference2 - Removed (Moved to IAcadExternalReference)
IAcadTable2 - Removed (Moved to IAcadTable)
IAcadOle2 - Removed (Moved to IAcadOle)
IAcadHelix2 - Removed (Moved to IAcadHelix)
IAcadSurface2 - Removed (Moved to IAcadSurface)
IAcadSurface3 - Removed (Moved to IAcadSurface)
IAcadPlaneSurface2 - Removed (Moved to IAcadPlaneSurface)
IAcadPlaneSurface3 - Removed (Moved to IAcadPlaneSurface)
IAcadExtrudedSurface2 - Removed (Moved to IAcadExtrudedSurface)
IAcadExtrudedSurface3 - Removed (Moved to IAcadExtrudedSurface)
IAcadRevolvedSurface2 - Removed (Moved to IAcadRevolvedSurface)
IAcadRevolvedSurface3 - Removed (Moved to IAcadRevolvedSurface)
IAcadSweptSurface2 - Removed (Moved to IAcadSweptSurface)
IAcadSweptSurface3 - Removed (Moved to IAcadSweptSurface)
IAcadLoftedSurface2 - Removed (Moved to IAcadLoftedSurface)
IAcadLoftedSurface3 - Removed (Moved to IAcadLoftedSurface)
IAcadWipeout2 - Removed (Moved to IAcadWipeout)
IAcadSubDMesh2 - Removed (Moved to IAcadSubDMesh)
IAcadNurbSurface2 - Removed (Moved to IAcadNurbSurface)
IAcadDimAligned2 - Removed (Moved to IAcadDimAligned)
IAcadDimAngular2 - Removed (Moved to IAcadDimAngular)
IAcadDimDiametric2 - Removed (Moved to IAcadDimDiametric)
IAcadDimOrdinate2 - Removed (Moved to IAcadDimOrdinate)
IAcadDimRadial2 - Removed (Moved to IAcadDimRadial)
IAcadDimRotated2 - Removed (Moved to IAcadDimRotated)
IAcadDim3PointAngular2 - Removed (Moved to IAcadDim3PointAngular)
IAcadDimArcLength2 - Removed (Moved to IAcadDimArcLength)
IAcadDimRadialLarge2 - Removed (Moved to IAcadDimRadialLarge)
GMT+8, 2026-11-16 02:59
