vlax-map-collection (AutoLISP/ActiveX)
将函数应用于集合中的所有对象 支持的平台:仅限 Windows;在 Mac OS 或 Web 上不可用 签名(vlax-map-collection obj function)
返回值类型:整数、实数、字符串、VLA 对象、变体、安全数组、T 或 nil obj 第一个参数。 例子(vlax-map-collection (vla-get-ModelSpace acadDocument) 'vlax-dump-object) ; IAcadLWPolyline: AutoCAD Lightweight Polyline Interface ; Property values: ; Application (RO) = #<VLA-OBJECT IAcadApplication 00a4ae24> ; Area (RO) = 2.46556 ; Closed = 0 ; Color = 256 ; ConstantWidth = 0.0 ; Coordinate = ...Indexed contents not shown... ; Coordinates = (8.49917 7.00155 11.2996 3.73137 14.8 5.74379 ... ) ; Database (RO) = #<VLA-OBJECT IAcadDatabase 01e3da44> ; Elevation = 0.0 ; Handle (RO) = "53" ; HasExtensionDictionary (RO) = 0 ; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 01e3d7d4> ; Layer = "0" ; Linetype = "BYLAYER" ; LinetypeGeneration = 0 ; LinetypeScale = 1.0 ; Lineweight = -1 ; Normal = (0.0 0.0 1.0) ; ObjectID (RO) = 28895576 ; ObjectName (RO) = "AcDbPolyline" ; PlotStyleName = "ByLayer" ; Thickness = 0.0 ; Visible = -1 T |
GMT+8, 2026-10-25 08:35
