Acad.CommandFlag 函数
2024-5-18 19:14| 发布者: admin| 查看: 915| 评论: 0|原作者: admin|来自: AutoCAD
Acad.CommandFlag 函数
Acad.CommandFlag 函数
文件
Autodesk.AutoCAD.js
语法
JavaScript的
function Acad.CommandFlag();
    "MODAL": 0x00000000,             // Modal command
    "TRANSPARENT": 0x00000001,       // Transparent command
    "USEPICKSET": 0x00000002,        // Use pre-selected objects
    "REDRAW": 0x00000004,            // Objects are redrawn upon completion of the command
    "NOPERSPECTIVE": 0x00000008,     // Restricted from perspective views
    "NOMULTIPLE": 0x00000010,        // Restricted from participating with the MULTIPLE command
    "NOTILEMODE": 0x00000020,        // Restricted from being used when TILEMODE = 1
    "NOPAPERSPACE": 0x00000040,      // Restricted from being used in Paper space
    "NOOEM": 0x00000100,             // Command not supported on AutoCAD OEM
    "UNDEFINED": 0x00000200,         // Declare command as undefined, can only be invoked via cmdGroupName.cmdGlobalName
    "INPROGRESS": 0x00000400,        // Indicated as being in progress; Internal use only
    "DEFUN": 0x00000800,             // Command was defined with the DEFUN function
    "LISPASCMD": 0x00001000,         // Internal use only
    "NONEWSTACK": 0x00010000,        // Command does not create a new item on the stack; Internal use only
    "NOINTERNALLOCK": 0x00020000,    // Document cannot be internally locked
    "DOCREADLOCK": 0x00080000,       // Not set = DOCWRITELOCK
    "DOCEXCLUSIVELOCK": 0x00100000,  // Not set = DOCSHAREDLOCK
    "SESSION": 0x00200000,           // Run command at session level rather than document
    "INTERRUPTIBLE": 0x00400000,     // Supports OPM display of command properties
    "NOHISTORY": 0x00800000,         // Command does not become default
    "NO_UNDO_MARKER": 0x01000000,    // No undo or repeat presence
    "NOBEDIT": 0x02000000,           // Restricted during Block Editor session
    "NOACTIONRECORDING": 0x04000000, // Restricted from Action Recording
    "ACTIONMACRO": 0x08000000,       // Supports Action Macro command
    "RELAXASSOC": 0x10000000,        // Allow relaxed network evaluation during drag operation
    "CORE": 0x20000000,              // Internal use only
    "NOINFERCONSTRAINT": 0x40000000, // Disallow Inferring Constraints
    "TEMPSHOWDYNDIM": 0x80000000     // Temporaily show dynamic dimensions for selected entities
群
ACAD 命名空间
描述
使用此枚举指定与 AutoCAD 命令关联的标志。
ACAD 命名空间
GMT+8, 2026-11-16 04:16
