AutoCAD 2024 开发者帮助
查询和设置布局设置 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 1009| 评论: 0|原作者: admin|来自: AutoCAD
查询和设置布局设置 (.NET)
以下示例演示如何查询和更改当前布局的设备。
VB.NET
Imports Autodesk.AutoCAD.PlottingServices
' Changes the plot settings for a layout directly
<CommandMethod("ChangeLayoutPlotSettings")> _
Public Shared Sub ChangeLayoutPlotSettings()
    ' Get the current document and database, and start a transaction
        ' Reference the Layout Manager
        Dim acLayoutMgr As LayoutManager = LayoutManager.Current
        ' Get the current layout and output its name in the Command Line window
        Dim acLayout As Layout = _
            acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), _
                              OpenMode.ForRead)
        ' Output the name of the current layout and its device
        acDoc.Editor.WriteMessage(vbLf & "Current layout: " & _
                                  acLayout.LayoutName)
        acDoc.Editor.WriteMessage(vbLf & "Current device name: " & _
                                  acLayout.PlotConfigurationName)
        ' Get a copy of the PlotSettings from the layout
        Using acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType)
            acPlSet.CopyFrom(acLayout)
            ' Update the PlotConfigurationName property of the PlotSettings object
            Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
            acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", _
                                                "ANSI_B_(11.00_x_17.00_Inches)")
            ' Zoom to show the whole paper
            acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, True)
            ' Update the layout
            acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForWrite)
            acLayout.CopyFrom(acPlSet)
        End Using
        ' Output the name of the new device assigned to the layout
        acDoc.Editor.WriteMessage(vbLf & "New device name: " & _
        ' Save the new objects to the database
        acTrans.Commit()
    End Using
    ' Update the display
    acDoc.Editor.Regen()
C#
using Autodesk.AutoCAD.PlottingServices;
// Changes the plot settings for a layout directly
[CommandMethod("ChangeLayoutPlotSettings")]
public static void ChangeLayoutPlotSettings()
    // Get the current document and database, and start a transaction
        // Reference the Layout Manager
        LayoutManager acLayoutMgr = LayoutManager.Current;
        // Get the current layout and output its name in the Command Line window
        Layout acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout),
                                            OpenMode.ForRead) as Layout;
        // Output the name of the current layout and its device
        acDoc.Editor.WriteMessage("\nCurrent layout: " + acLayout.LayoutName);
        acDoc.Editor.WriteMessage("\nCurrent device name: " + acLayout.PlotConfigurationName);
        // Get a copy of the PlotSettings from the layout
        using (PlotSettings acPlSet = new PlotSettings(acLayout.ModelType))
            acPlSet.CopyFrom(acLayout);
            // Update the PlotConfigurationName property of the PlotSettings object
            PlotSettingsValidator acPlSetVdr = PlotSettingsValidator.Current;
            acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ANSI_B_(11.00_x_17.00_Inches)");
            // Zoom to show the whole paper
            acPlSetVdr.SetZoomToPaperOnUpdate(acPlSet, true);
            // Update the layout
            acTrans.GetObject(acLayoutMgr.GetLayoutId(acLayoutMgr.CurrentLayout), OpenMode.ForWrite);
            acLayout.CopyFrom(acPlSet);
        // Output the name of the new device assigned to the layout
        acDoc.Editor.WriteMessage("\nNew device name: " + acLayout.PlotConfigurationName);
        // Save the new objects to the database
        acTrans.Commit();
    // Update the display
    acDoc.Editor.Regen();
VBA/ActiveX 代码参考
Public Sub ChangePlotSetting()
    Dim layoutObj As AcadLayout
    Set layoutObj = ThisDrawing.ActiveLayout
    ThisDrawing.Utility.Prompt vbLf & "Current layout: " & layoutObj.Name
    ThisDrawing.Utility.Prompt vbLf & "Current device name: " & _
                               layoutObj.ConfigName
    ' Change the name of the output device for the current layout
    layoutObj.RefreshPlotDeviceInfo
    layoutObj.ConfigName = "DWF6 ePlot.pc3"
    layoutObj.CanonicalMediaName = "ANSI_A_(8.50_x_11.00_Inches)"
                               layoutObj.ConfigName & vbLf
GMT+8, 2026-10-23 17:41
