AutoCAD 2024 开发者帮助
分配和检索扩展数据 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 893| 评论: 0|原作者: admin|来自: AutoCAD
分配和检索扩展数据 (.NET)
可以使用扩展数据 (xdata) 作为将信息与图形中的对象链接的方法。
将 xdata 分配给选择集中的所有对象
本示例提示用户从图形中选取对象。所选对象将放置到选择集中,并且指定的 xdata 将附加到该选择集中的所有对象。
VB.NET
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("AttachXDataToSelectionSetObjects")> _
Public Sub AttachXDataToSelectionSetObjects()
    ' Get the current database and start a transaction
    Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
    acCurDb = Application.DocumentManager.MdiActiveDocument.Database
    Dim appName As String = "MY_APP"
    Dim xdataStr As String = "This is some xdata"
        ' Request objects to be selected in the drawing area
        Dim acSSPrompt As PromptSelectionResult = acDoc.Editor.GetSelection()
        ' If the prompt status is OK, objects were selected
        If acSSPrompt.Status = PromptStatus.OK Then
            ' Open the Registered Applications table for read
            Dim acRegAppTbl As RegAppTable
            acRegAppTbl = acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForRead)
            ' Check to see if the Registered Applications table record for the custom app exists
            Dim acRegAppTblRec As RegAppTableRecord
            If acRegAppTbl.Has(appName) = False Then
                acRegAppTblRec = New RegAppTableRecord
                acRegAppTblRec.Name = appName
                acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForWrite)
                acRegAppTbl.Add(acRegAppTblRec)
                acTrans.AddNewlyCreatedDBObject(acRegAppTblRec, True)
            End If
            ' Define the Xdata to add to each selected object
            Using rb As New ResultBuffer
                rb.Add(New TypedValue(DxfCode.ExtendedDataRegAppName, appName))
                rb.Add(New TypedValue(DxfCode.ExtendedDataAsciiString, xdataStr))
                Dim acSSet As SelectionSet = acSSPrompt.Value
                ' Step through the objects in the selection set
                For Each acSSObj As SelectedObject In acSSet
                    ' Open the selected object for write
                    Dim acEnt As Entity = acTrans.GetObject(acSSObj.ObjectId, _
                                                            OpenMode.ForWrite)
                    ' Append the extended data to each object
                    acEnt.XData = rb
                Next
            End Using
        End If
        ' Save the new object to the database
        acTrans.Commit()
        ' Dispose of the transaction
    End Using
C#
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("AttachXDataToSelectionSetObjects")]
public void AttachXDataToSelectionSetObjects()
    // Get the current database and start a transaction
    Database acCurDb;
    acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
    string appName = "MY_APP";
    string xdataStr = "This is some xdata";
        // Request objects to be selected in the drawing area
        PromptSelectionResult acSSPrompt = acDoc.Editor.GetSelection();
        // If the prompt status is OK, objects were selected
        if (acSSPrompt.Status == PromptStatus.OK)
            // Open the Registered Applications table for read
            RegAppTable acRegAppTbl;
            acRegAppTbl = acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForRead) as RegAppTable;
            // Check to see if the Registered Applications table record for the custom app exists
            if (acRegAppTbl.Has(appName) == false)
                using (RegAppTableRecord acRegAppTblRec = new RegAppTableRecord())
                    acRegAppTblRec.Name = appName;
                    acTrans.GetObject(acCurDb.RegAppTableId, OpenMode.ForWrite);
                    acRegAppTbl.Add(acRegAppTblRec);
                    acTrans.AddNewlyCreatedDBObject(acRegAppTblRec, true);
            // Define the Xdata to add to each selected object
            using (ResultBuffer rb = new ResultBuffer())
                rb.Add(new TypedValue((int)DxfCode.ExtendedDataRegAppName, appName));
                rb.Add(new TypedValue((int)DxfCode.ExtendedDataAsciiString, xdataStr));
                SelectionSet acSSet = acSSPrompt.Value;
                // Step through the objects in the selection set
                foreach (SelectedObject acSSObj in acSSet)
                    // Open the selected object for write
                    Entity acEnt = acTrans.GetObject(acSSObj.ObjectId,
                                                        OpenMode.ForWrite) as Entity;
                    // Append the extended data to each object
                    acEnt.XData = rb;
        // Save the new object to the database
        acTrans.Commit();
        // Dispose of the transaction
VBA/ActiveX 代码参考
    ' Create the selection set
    Dim sset As Object
    Set sset = ThisDrawing.SelectionSets.Add("SS1")
    ' Prompt the user to select objects
    sset.SelectOnScreen
    ' Define the xdata
    Dim appName As String, xdataStr As String
    appName = "MY_APP"
    Dim xdataType(0 To 1) As Integer
    Dim xdata(0 To 1) As Variant
    ' Define the values for each array
    ' 1001 indicates the appName
    xdataType(0) = 1001
    xdata(0) = appName
    ' 1000 indicates a string value
    xdataType(1) = 1000
    xdata(1) = xdataStr
    ' Loop through all entities in the selection
    ' set and assign the xdata to each entity
    Dim ent As Object
    For Each ent In sset
        ent.SetXData xdataType, xdata
    Next ent
查看选择集中所有对象的 xdata
此示例显示与上一个示例一起附加的 xdata。如果附加字符串以外的 xdata(类型 1000),则需要修改此代码。
VB.NET
<CommandMethod("ViewXData")> _
Public Sub ViewXData()
    Dim msgstr As String = ""
                ' Open the selected object for read
                                                        OpenMode.ForRead)
                ' Get the extended data attached to each object for MY_APP
                Dim rb As ResultBuffer = acEnt.GetXDataForApplication(appName)
                ' Make sure the Xdata is not empty
                If Not IsNothing(rb) Then
                    ' Get the values in the xdata
                    For Each typeVal As TypedValue In rb
                        msgstr = msgstr & vbCrLf & typeVal.TypeCode.ToString() & ":" & typeVal.Value
                    Next
                Else
                    msgstr = "NONE"
                End If
                ' Display the values returned
                MsgBox(appName & " xdata on " & VarType(acEnt).ToString() & ":" & vbCrLf & msgstr)
                msgstr = ""
            Next
        End If
        ' Ends the transaction and ensures any changes made are ignored
        acTrans.Abort()
    End Using
C#
[CommandMethod("ViewXData")]
public void ViewXData()
    Database acCurDb;
    string msgstr = "";
                // Open the selected object for read
                                                 OpenMode.ForRead) as Entity;
                // Get the extended data attached to each object for MY_APP
                ResultBuffer rb = acEnt.GetXDataForApplication(appName);
                // Make sure the Xdata is not empty
                if (rb != null)
                    // Get the values in the xdata
                    foreach (TypedValue typeVal in rb)
                        msgstr = msgstr + "\n" + typeVal.TypeCode.ToString() + ":" + typeVal.Value;
                else
                    msgstr = "NONE";
                // Display the values returned
                Application.ShowAlertDialog(appName + " xdata on " + acEnt.GetType().ToString() + ":\n" + msgstr);
                msgstr = "";
        // Ends the transaction and ensures any changes made are ignored
        acTrans.Abort();
VBA/ActiveX 代码参考
Sub ViewXData()
    ' Find the selection created in previous example
    Dim sset As Object
    Set sset = ThisDrawing.SelectionSets.Item("SS1")
    ' Define the xdata variables to hold xdata information
    Dim xdataType As Variant
    Dim xdata As Variant
    Dim xd As Variant
    ' Define index counter
    Dim xdi As Integer
    xdi = 0
    ' Loop through the objects in the selection set
    ' and retrieve the xdata for the object
    Dim ent As AcadEntity
    appName = "MY_APP"
        msgstr = ""
        xdi = 0
        ' Retrieve the appName xdata type and value
        ent.GetXData appName, xdataType, xdata
        ' If the xdataType variable is not initialized, there
        ' was no appName xdata to retrieve for that entity
        If VarType(xdataType) <> vbEmpty Then
            For Each xd In xdata
                msgstr = msgstr & vbCrLf & xdataType(xdi) & ": " & xd
                xdi = xdi + 1
            Next xd
        End If
        ' If the msgstr variable is NULL, there was no xdata
        If msgstr = "" Then msgstr = vbCrLf & "NONE"
        MsgBox appName & " xdata on " & ent.ObjectName & ":" & vbCrLf & msgstr
    Next ent
GMT+8, 2026-10-22 20:50
