AutoCAD 2024 开发者帮助
分解块引用 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 808| 评论: 0|原作者: admin|来自: AutoCAD
分解块引用 (.NET)
使用该方法中断块引用。通过分解块参照,可以修改块,或者添加或删除定义块的对象。Explode
显示分解块参照的结果
此示例创建一个块,并在该块的定义中添加一个圆圈。然后,将块作为块参照插入到图形中。然后分解块参照,并显示分解过程生成的对象及其对象类型。
VB.NET
<CommandMethod("ExplodingABlock")> _
Public Sub ExplodingABlock()
    ' Get the current database and start a transaction
    Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
    acCurDb = Application.DocumentManager.MdiActiveDocument.Database
        ' Open the Block table for read
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
        Dim blkRecId As ObjectId = ObjectId.Null
        If Not acBlkTbl.Has("CircleBlock") Then
            Using acBlkTblRec As New BlockTableRecord
                acBlkTblRec.Name = "CircleBlock"
                ' Set the insertion point for the block
                acBlkTblRec.Origin = New Point3d(0, 0, 0)
                ' Add a circle to the block
                Using acCirc As New Circle
                    acCirc.Center = New Point3d(0, 0, 0)
                    acCirc.Radius = 2
                    acBlkTblRec.AppendEntity(acCirc)
                    acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite)
                    acBlkTbl.Add(acBlkTblRec)
                    acTrans.AddNewlyCreatedDBObject(acBlkTblRec, True)
                End Using
                blkRecId = acBlkTblRec.Id
            End Using
        Else
            blkRecId = acBlkTbl("CircleBlock")
        End If
        ' Insert the block into the current space
        If blkRecId <> ObjectId.Null Then
            Using acBlkRef As New BlockReference(New Point3d(0, 0, 0), blkRecId)
                Dim acCurSpaceBlkTblRec As BlockTableRecord
                acCurSpaceBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite)
                acCurSpaceBlkTblRec.AppendEntity(acBlkRef)
                acTrans.AddNewlyCreatedDBObject(acBlkRef, True)
                Using dbObjCol As New DBObjectCollection
                    acBlkRef.Explode(dbObjCol)
                    For Each dbObj As DBObject In dbObjCol
                        Dim acEnt As Entity = dbObj
                        acCurSpaceBlkTblRec.AppendEntity(acEnt)
                        acTrans.AddNewlyCreatedDBObject(dbObj, True)
                        acEnt = acTrans.GetObject(dbObj.ObjectId, OpenMode.ForWrite)
                        acEnt.ColorIndex = 1
                        MsgBox("Exploded Object: " & acEnt.GetRXClass().DxfName)
                    Next
                End Using
            End Using
        End If
        ' Save the new object to the database
        acTrans.Commit()
        ' Dispose of the transaction
    End Using
C#
[CommandMethod("ExplodingABlock")]
public void ExplodingABlock()
    // Get the current database and start a transaction
    Database acCurDb;
    acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
        BlockTable acBlkTbl;
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
        ObjectId blkRecId = ObjectId.Null;
        if (!acBlkTbl.Has("CircleBlock"))
            using (BlockTableRecord acBlkTblRec = new BlockTableRecord())
                acBlkTblRec.Name = "CircleBlock";
                // Set the insertion point for the block
                acBlkTblRec.Origin = new Point3d(0, 0, 0);
                // Add a circle to the block
                using (Circle acCirc = new Circle())
                    acCirc.Center = new Point3d(0, 0, 0);
                    acCirc.Radius = 2;
                    acBlkTblRec.AppendEntity(acCirc);
                    acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForWrite);
                    acBlkTbl.Add(acBlkTblRec);
                    acTrans.AddNewlyCreatedDBObject(acBlkTblRec, true);
                blkRecId = acBlkTblRec.Id;
        else
            blkRecId = acBlkTbl["CircleBlock"];
        // Insert the block into the current space
        if (blkRecId != ObjectId.Null)
            using (BlockReference acBlkRef = new BlockReference(new Point3d(0, 0, 0), blkRecId))
                BlockTableRecord acCurSpaceBlkTblRec;
                acCurSpaceBlkTblRec = acTrans.GetObject(acCurDb.CurrentSpaceId, OpenMode.ForWrite) as BlockTableRecord;
                acCurSpaceBlkTblRec.AppendEntity(acBlkRef);
                acTrans.AddNewlyCreatedDBObject(acBlkRef, true);
                using (DBObjectCollection dbObjCol = new DBObjectCollection())
                    acBlkRef.Explode(dbObjCol);
                    foreach (DBObject dbObj in dbObjCol)
                        Entity acEnt = dbObj as Entity;
                        acCurSpaceBlkTblRec.AppendEntity(acEnt);
                        acTrans.AddNewlyCreatedDBObject(dbObj, true);
                        acEnt = acTrans.GetObject(dbObj.ObjectId, OpenMode.ForWrite) as Entity;
                        acEnt.ColorIndex = 1;
                        Application.ShowAlertDialog("Exploded Object: " + acEnt.GetRXClass().DxfName);
        // Save the new object to the database
        acTrans.Commit();
        // Dispose of the transaction
VBA/ActiveX 代码参考
    ' Define the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0
    insertionPnt(1) = 0
    insertionPnt(2) = 0
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 0
    center(1) = 0
    center(2) = 0
    rad = 2
    Set circleObj = blockObj.AddCircle(center, rad)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 0
    insertionPnt(1) = 0
    insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1, 1, 1, 0)
    ' Explode the block reference
    Dim explodedObjects As Variant
    explodedObjects = blockRefObj.Explode
    ' Loop through the exploded objects
    Dim I As Integer
    For I = 0 To UBound(explodedObjects)
        explodedObjects(I).Color = acRed
        explodedObjects(I).Update
        MsgBox "Exploded Object " & I & ": " & explodedObjects(I).ObjectName
    Next
  1. 使用块 (.NET)
GMT+8, 2026-10-23 12:44
