指定 3D 坐标 (.NET)
输入 3D 世界坐标系 (WCS) 坐标类似于输入 2D WCS 坐标。除了指定 X 和 Y 值外,还可以指定 Z 值。2D 坐标由对象表示,而使用对象表示 3D 坐标。AutoCAD .NET API 中的大多数属性和方法都使用 3D 坐标。Point2dPoint3d 定义和查询 2D 和 3D 折线的坐标本示例创建两条折线,每条折线都有三个坐标。第一条折线是 2D 折线,第二条折线是 3D 折线。请注意,在创建 3D 折线时,包含顶点的数组的长度将展开以包括 Z 坐标。该示例最后查询折线的坐标并在消息框中显示坐标。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("Polyline_2D_3D")> _
Public Sub Polyline_2D_3D()
'' Get the current document and database, and start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a polyline with two segments (3 points)
Using acPoly As Polyline = New Polyline()
acPoly.AddVertexAt(0, New Point2d(1, 1), 0, 0, 0)
acPoly.AddVertexAt(1, New Point2d(1, 2), 0, 0, 0)
acPoly.AddVertexAt(2, New Point2d(2, 2), 0, 0, 0)
acPoly.ColorIndex = 1
acBlkTblRec.AppendEntity(acPoly)
acTrans.AddNewlyCreatedDBObject(acPoly, True)
'' Create a 3D polyline with two segments (3 points)
Using acPoly3d As Polyline3d = New Polyline3d()
acPoly3d.ColorIndex = 5
acBlkTblRec.AppendEntity(acPoly3d)
acTrans.AddNewlyCreatedDBObject(acPoly3d, True)
'' Before adding vertexes, the polyline must be in the drawing
Dim acPts3dPoly As Point3dCollection = New Point3dCollection()
acPts3dPoly.Add(New Point3d(1, 1, 0))
acPts3dPoly.Add(New Point3d(2, 1, 0))
acPts3dPoly.Add(New Point3d(2, 2, 0))
For Each acPt3d As Point3d In acPts3dPoly
Using acPolVer3d As PolylineVertex3d = New PolylineVertex3d(acPt3d)
acPoly3d.AppendVertex(acPolVer3d)
acTrans.AddNewlyCreatedDBObject(acPolVer3d, True)
End Using
Next
'' Get the coordinates of the lightweight polyline
Dim acPts2d As Point2dCollection = New Point2dCollection()
For nCnt As Integer = 0 To acPoly.NumberOfVertices - 1
acPts2d.Add(acPoly.GetPoint2dAt(nCnt))
Next
'' Get the coordinates of the 3D polyline
Dim acPts3d As Point3dCollection = New Point3dCollection()
For Each acObjIdVert As ObjectId In acPoly3d
Dim acPolVer3d As PolylineVertex3d
acPolVer3d = acTrans.GetObject(acObjIdVert, _
OpenMode.ForRead)
acPts3d.Add(acPolVer3d.Position)
Next
'' Display the Coordinates
Application.ShowAlertDialog("2D polyline (red): " & vbLf & _
acPts2d(0).ToString() & vbLf & _
acPts2d(1).ToString() & vbLf & _
acPts2d(2).ToString())
Application.ShowAlertDialog("3D polyline (blue): " & vbLf & _
acPts3d(0).ToString() & vbLf & _
acPts3d(1).ToString() & vbLf & _
acPts3d(2).ToString())
End Using
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("Polyline_2D_3D")]
public static void Polyline_2D_3D()
// Get the current document and database, and start a transaction
// Open the Block table record for read
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a polyline with two segments (3 points)
using (Polyline acPoly = new Polyline())
acPoly.AddVertexAt(0, new Point2d(1, 1), 0, 0, 0);
acPoly.AddVertexAt(1, new Point2d(1, 2), 0, 0, 0);
acPoly.AddVertexAt(2, new Point2d(2, 2), 0, 0, 0);
acPoly.ColorIndex = 1;
acBlkTblRec.AppendEntity(acPoly);
acTrans.AddNewlyCreatedDBObject(acPoly, true);
// Create a 3D polyline with two segments (3 points)
using (Polyline3d acPoly3d = new Polyline3d())
acPoly3d.ColorIndex = 5;
acBlkTblRec.AppendEntity(acPoly3d);
acTrans.AddNewlyCreatedDBObject(acPoly3d, true);
// Before adding vertexes, the polyline must be in the drawing
Point3dCollection acPts3dPoly = new Point3dCollection();
acPts3dPoly.Add(new Point3d(1, 1, 0));
acPts3dPoly.Add(new Point3d(2, 1, 0));
acPts3dPoly.Add(new Point3d(2, 2, 0));
foreach (Point3d acPt3d in acPts3dPoly)
using (PolylineVertex3d acPolVer3d = new PolylineVertex3d(acPt3d))
acPoly3d.AppendVertex(acPolVer3d);
acTrans.AddNewlyCreatedDBObject(acPolVer3d, true);
// Get the coordinates of the lightweight polyline
Point2dCollection acPts2d = new Point2dCollection();
for (int nCnt = 0; nCnt < acPoly.NumberOfVertices; nCnt++)
acPts2d.Add(acPoly.GetPoint2dAt(nCnt));
// Get the coordinates of the 3D polyline
Point3dCollection acPts3d = new Point3dCollection();
foreach (ObjectId acObjIdVert in acPoly3d)
PolylineVertex3d acPolVer3d;
OpenMode.ForRead) as PolylineVertex3d;
acPts3d.Add(acPolVer3d.Position);
// Display the Coordinates
Application.ShowAlertDialog("2D polyline (red): \n" +
acPts2d[0].ToString() + "\n" +
acPts2d[1].ToString() + "\n" +
acPts2d[2].ToString());
Application.ShowAlertDialog("3D polyline (blue): \n" +
acPts3d[0].ToString() + "\n" +
acPts3d[1].ToString() + "\n" +
acPts3d[2].ToString());
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub Polyline_2D_3D()
Dim pline2DObj As AcadLWPolyline
Dim pline3DObj As AcadPolyline
Dim points2D(0 To 5) As Double
Dim points3D(0 To 8) As Double
' Define three 2D polyline points
points2D(0) = 1: points2D(1) = 1
points2D(2) = 1: points2D(3) = 2
points2D(4) = 2: points2D(5) = 2
' Define three 3D polyline points
points3D(0) = 1: points3D(1) = 1: points3D(2) = 0
points3D(3) = 2: points3D(4) = 1: points3D(5) = 0
points3D(6) = 2: points3D(7) = 2: points3D(8) = 0
' Create the 2D light weight Polyline
Set pline2DObj = ThisDrawing.ModelSpace. _
AddLightWeightPolyline(points2D)
pline2DObj.Color = acRed
pline2DObj.Update
' Create the 3D polyline
Set pline3DObj = ThisDrawing.ModelSpace. _
AddPolyline(points3D)
pline3DObj.Color = acBlue
pline3DObj.Update
' Query the coordinates of the polylines
Dim get2Dpts As Variant
Dim get3Dpts As Variant
get2Dpts = pline2DObj.Coordinates
get3Dpts = pline3DObj.Coordinates
' Display the coordinates
MsgBox ("2D polyline (red): " & vbCrLf & "(" & _
get2Dpts(0) & ", " & get2Dpts(1) & ")" & vbCrLf & "(" & _
get2Dpts(2) & ", " & get2Dpts(3) & ")"& vbCrLf & "(" & _
get2Dpts(4) & ", " & get2Dpts(5) & ")")
MsgBox ("3D polyline (blue): " & vbCrLf & "(" & _
get3Dpts(0) & ", " & get3Dpts(1) & ", " & _
get3Dpts(2) & ")" & vbCrLf & "(" & _
get3Dpts(3) & ", " & get3Dpts(4) & ", " & _
get3Dpts(5) & ")" & vbCrLf & "(" & _
get3Dpts(6) & ", " & get3Dpts(7) & ", " & _
get3Dpts(8) & ")")
相关概念父主题: |
GMT+8, 2026-10-22 20:59
