AutoCAD 2024 开发者帮助
创建弧长尺寸 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 685| 评论: 0|原作者: admin|来自: AutoCAD
创建弧长尺寸 (.NET)
弧长尺寸测量沿圆弧的长度,并显示带有弧符号的尺寸文本,该符号位于弧上方或继续上方。当需要标注圆弧的实际长度而不仅仅是其起点和终点之间的距离时,可以使用圆弧长度尺寸。
通过创建对象的实例来创建弧长半径尺寸。创建对象的实例时,它需要一组定义维度的参数。创建新对象时,必须提供以下参数:ArcDimensionArcDimensionArcDimension
  • 中心点 ( 属性)Center
  • 延长线 1 点 ( 属性)XLine1Point
  • 延长线2点(属性)XLine2Point
  • Arc point ( 属性)ArcPoint
  • 维度文本(属性)DimensionText
  • 维度样式(或属性)DimensionStyleNameDimensionStyle
注意:DIMARCSYM 系统变量控制是否显示圆弧符号以及该符号相对于尺寸文本的显示位置。
创建弧长尺寸
本示例在模型空间中创建弧长尺寸。
VB.NET
<CommandMethod("CreateArcLengthDimension")> _
Public Sub CreateArcLengthDimension()
    '' Get the current database
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create an arc length dimension
        Using acArcDim As ArcDimension = New ArcDimension(New Point3d(4.5, 1.5, 0), _
                                                          New Point3d(8, 4.25, 0), _
                                                          New Point3d(0, 2, 0), _
                                                          New Point3d(5, 7, 0), _
                                                          "<>", _
                                                          acCurDb.Dimstyle)
            '' Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acArcDim)
            acTrans.AddNewlyCreatedDBObject(acArcDim, True)
        End Using
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreateArcLengthDimension")]
public static void CreateArcLengthDimension()
    // Get the current database
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create an arc length dimension
        using (ArcDimension acArcDim = new ArcDimension(new Point3d(4.5, 1.5, 0),
                                                        new Point3d(8, 4.25, 0),
                                                        new Point3d(0, 2, 0),
                                                        new Point3d(5, 7, 0),
                                                        acCurDb.Dimstyle))
            // Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acArcDim);
            acTrans.AddNewlyCreatedDBObject(acArcDim, true);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim dimObj As AcadDimArcLength
    Dim arcCenterPoint(0 To 2) As Double
    Dim firstPoint(0 To 2) As Double
    Dim secondPoint(0 To 2) As Double
    Dim arcPoint(0 To 2) As Double
    ' Define the dimension
    arcCenterPoint(0) = 4.5: arcCenterPoint(1) = 1.5: arcCenterPoint(2) = 0
    firstPoint(0) = 8: firstPoint(1) = 4.25: firstPoint(2) = 0
    secondPoint(0) = 0: secondPoint(1) = 2: secondPoint(2) = 0
    arcPoint(0) = 5: arcPoint(1) = 7: arcPoint(2) = 0
    ' Create the arc length dimension in Model space
    Set dimObj = ThisDrawing.ModelSpace. _
                     AddDimArc(arcCenterPoint, firstPoint, _
                     secondPoint, arcPoint)
    ZoomAll
GMT+8, 2026-10-23 13:47
