AutoCAD 2024 开发者帮助
设置文本生成标志 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 697| 评论: 0|原作者: admin|来自: AutoCAD
设置文本生成标志 (.NET)
文本生成标志指定文本是向后显示还是倒置显示。使用该属性可以定义文本样式是控制要向后显示的文本的显示还是倒置显示,或者使用文本对象的 and 属性来单独控制文本对象。FlagBitsIsMirroredInXIsMirroredInY
如果希望向后显示文本,请设置为 2,如果要倒置显示文本,请设置为 4。使用值 6 向后和上下显示文本。如果要修改文本对象,请设置为“如果希望文本向后显示”,如果希望将其倒置显示,请设置为“TRUE”。FlagBitsIsMirroredInXTRUEIsMirroredInY
向后显示文本
下面的示例创建一个单行文本对象,然后使用该属性将其设置为向后显示。IsMirroredInX
VB.NET
<CommandMethod("BackwardsText")> _
Public Sub BackwardsText()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a single-line text object
        Using acText As DBText = New DBText()
            acText.Position = New Point3d(3, 3, 0)
            acText.Height = 0.5
            acText.TextString = "Hello, World."
            '' Display the text backwards
            acText.IsMirroredInX = True
            acBlkTblRec.AppendEntity(acText)
            acTrans.AddNewlyCreatedDBObject(acText, True)
        End Using
        '' Save the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("BackwardsText")]
public static void BackwardsText()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a single-line text object
        using (DBText acText = new DBText())
            acText.Position = new Point3d(3, 3, 0);
            acText.Height = 0.5;
            acText.TextString = "Hello, World.";
            // Display the text backwards
            acText.IsMirroredInX = true;
            acBlkTblRec.AppendEntity(acText);
            acTrans.AddNewlyCreatedDBObject(acText, true);
        // Save the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub BackwardsText()
    Dim textObj As AcadText
    Dim textString As String
    Dim height As Double
    ' Create the text object
    textString = "Hello, World."
    insertionPoint(0) = 3
    insertionPoint(1) = 3
    insertionPoint(2) = 0
    height = 0.5
    Set textObj = ThisDrawing.ModelSpace. _
                      AddText(textString, insertionPoint, height)
    ' Change the value of the TextGenerationFlag
    textObj.TextGenerationFlag = acTextFlagBackward
    textObj.Update
GMT+8, 2026-10-23 14:57
