AutoCAD 2024 开发者帮助
了解 AutoCAD 如何保存图层状态 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 1024| 评论: 0|原作者: admin|来自: AutoCAD
AutoCAD 将图层设置信息保存在对象的扩展字典中。首次保存图层状态时,AutoCAD 将执行以下操作:LayerTable
  • 在“图层”(Layers) 表上创建扩展字典。
  • 在扩展字典中创建名为 ACAD_LAYERSTATE 的对象。Dictionary
  • 将绘图中每个图层的属性存储在ACAD_LAYERSTATE字典中的对象中。AutoCAD 将所有图层设置存储在 中,但会标识您选择保存的特定设置。恢复图层设置时,AutoCAD 仅恢复您选择保存的设置。XRecordXRecord
每次在图形中保存另一个图层设置时,AutoCAD 都会创建另一个对象来描述所保存的设置,并将其存储在 ACAD_LAYERSTATE 字典中。下图说明了该过程。XRecordXRecord
在处理图层状态时,您不需要(也不应尝试)直接操作条目。使用对象的函数访问字典。一旦您引用了字典,您就可以单步执行表示为对象的每个条目。LayerStateManagerDBDictionaryEntry
列出图形中保存的图层状态
如果已在当前图形中保存了图层状态,则以下代码将列出所有已保存的图层状态的名称:
VB.NET
<CommandMethod("ListLayerStates")> _
Public Sub ListLayerStates()
    '' Start a transaction
        Dim acLyrStMan As LayerStateManager
        acLyrStMan = acCurDb.LayerStateManager
        Dim acDbDict As DBDictionary
        acDbDict = acTrans.GetObject(acLyrStMan.LayerStatesDictionaryId(True), _
                                     OpenMode.ForRead)
        Dim sLayerStateNames As String = ""
        For Each acDbDictEnt As DBDictionaryEntry In acDbDict
            sLayerStateNames = sLayerStateNames & vbLf & acDbDictEnt.Key
        Next
        Application.ShowAlertDialog("The saved layer settings in this drawing are:" & _
                                    sLayerStateNames)
        '' Dispose of the transaction
    End Using
C#
[CommandMethod("ListLayerStates")]
public static void ListLayerStates()
    // Start a transaction
        LayerStateManager acLyrStMan;
        acLyrStMan = acCurDb.LayerStateManager;
        DBDictionary acDbDict;
        acDbDict = acTrans.GetObject(acLyrStMan.LayerStatesDictionaryId(true),
                                        OpenMode.ForRead) as DBDictionary;
        string sLayerStateNames = "";
        foreach (DBDictionaryEntry acDbDictEnt in acDbDict)
            sLayerStateNames = sLayerStateNames + "\n" + acDbDictEnt.Key;
        Application.ShowAlertDialog("The saved layer settings in this drawing are:" +
                                    sLayerStateNames);
        // Dispose of the transaction
VBA/ActiveX 代码参考
     On Error Resume Next
    Dim oLSMDict As AcadDictionary
    Dim XRec As Object
    Dim layerstateNames As String
    layerstateNames = ""
    ' Get the ACAD_LAYERSTATES dictionary, which is in the
    ' extension dictionary in the Layers object.
    Set oLSMDict = ThisDrawing.Layers. _
                               GetExtensionDictionary.Item("ACAD_LAYERSTATES")
    ' List the name of each saved layer setting. Settings are
    ' stored as XRecords in the dictionary.
    For Each XRec In oLSMDict
       layerstateNames = layerstateNames + XRec.Name + vbCrLf
    Next XRec
    MsgBox "The saved layer settings in this drawing are: " + _
           vbCrLf + layerstateNames
GMT+8, 2026-10-23 11:18
