旋转对象 (.NET)
可以旋转所有图形对象和属性参照对象。 要旋转对象,请使用变换矩阵的函数。此函数需要以弧度表示的旋转角度、旋转轴和基点。旋转轴必须表示为对象,基点必须表示为对象。此角度决定了对象相对于其当前位置围绕基点旋转的距离。RotationVector3dPoint3d ![]() 绕基点旋转折线本示例创建闭合的轻量级折线,然后将折线绕基点 (4, 4.25, 0) 旋转 45 度。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("RotateObject")> _
Public Sub RotateObject()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a lightweight polyline
Using acPoly As Polyline = New Polyline()
acPoly.AddVertexAt(0, New Point2d(1, 2), 0, 0, 0)
acPoly.AddVertexAt(1, New Point2d(1, 3), 0, 0, 0)
acPoly.AddVertexAt(2, New Point2d(2, 3), 0, 0, 0)
acPoly.AddVertexAt(3, New Point2d(3, 3), 0, 0, 0)
acPoly.AddVertexAt(4, New Point2d(4, 4), 0, 0, 0)
acPoly.AddVertexAt(5, New Point2d(4, 2), 0, 0, 0)
'' Close the polyline
acPoly.Closed = True
Dim curUCSMatrix As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d
'' Rotate the polyline 45 degrees, around the Z-axis of the current UCS
'' using a base point of (4,4.25,0)
acPoly.TransformBy(Matrix3d.Rotation(0.7854, _
curUCS.Zaxis, _
New Point3d(4, 4.25, 0)))
acBlkTblRec.AppendEntity(acPoly)
acTrans.AddNewlyCreatedDBObject(acPoly, True)
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("RotateObject")]
public static void RotateObject()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a lightweight polyline
using (Polyline acPoly = new Polyline())
acPoly.AddVertexAt(0, new Point2d(1, 2), 0, 0, 0);
acPoly.AddVertexAt(1, new Point2d(1, 3), 0, 0, 0);
acPoly.AddVertexAt(2, new Point2d(2, 3), 0, 0, 0);
acPoly.AddVertexAt(3, new Point2d(3, 3), 0, 0, 0);
acPoly.AddVertexAt(4, new Point2d(4, 4), 0, 0, 0);
acPoly.AddVertexAt(5, new Point2d(4, 2), 0, 0, 0);
// Close the polyline
acPoly.Closed = true;
Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
// Rotate the polyline 45 degrees, around the Z-axis of the current UCS
// using a base point of (4,4.25,0)
curUCS.Zaxis,
new Point3d(4, 4.25, 0)));
acBlkTblRec.AppendEntity(acPoly);
acTrans.AddNewlyCreatedDBObject(acPoly, true);
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub RotateObject()
' Create the polyline
Dim points(0 To 11) As Double
points(0) = 1: points(1) = 2
points(2) = 1: points(3) = 3
points(4) = 2: points(5) = 3
points(6) = 3: points(7) = 3
points(8) = 4: points(9) = 4
points(10) = 4: points(11) = 2
Set plineObj = ThisDrawing.ModelSpace. _
AddLightWeightPolyline(points)
plineObj.Closed = True
ZoomAll
' Define the rotation of 45 degrees about a
' base point of (4, 4.25, 0)
Dim basePoint(0 To 2) As Double
Dim rotationAngle As Double
basePoint(0) = 4: basePoint(1) = 4.25: basePoint(2) = 0
rotationAngle = 0.7853981 ' 45 degrees
plineObj.Rotate basePoint, rotationAngle
plineObj.Update
相关概念父主题: |
GMT+8, 2026-10-23 11:50
