AutoCAD 2024 开发者帮助
创建区域 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 1007| 评论: 0|原作者: admin|来自: AutoCAD
创建区域 (.NET)
通过创建对象的实例,然后将其追加到 .在将其添加到对象之前,需要根据形成闭环的对象计算区域。该函数在对象的输入数组形成的每个闭环中创建一个区域。该方法返回并需要一个对象。BlockTableRecordRegionBlockTableRecordBlockTableRecordCreateFromCurvesCreateFromCurvesDBObjectCollection
AutoCAD 将闭合的 2D 和平面 3D 多段线转换为单独的区域,然后转换形成闭合平面环的多段线、直线和曲线。如果两条以上的曲线共享一个端点,则生成的区域可能是任意的。因此,实际上可以使用该方法创建多个区域。您需要将创建的每个区域附加到对象中。CreateFromCurvesBlockTableRecord
创建简单区域
以下示例从单个圆圈创建区域。
VB.NET
<CommandMethod("AddRegion")> _
Public Sub AddRegion()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create an in memory circle
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 2, 0)
            acCirc.Radius = 5
            '' Adds the circle to an object array
            Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
            acDBObjColl.Add(acCirc)
            '' Calculate the regions based on each closed loop
            Dim myRegionColl As DBObjectCollection = New DBObjectCollection()
            myRegionColl = Region.CreateFromCurves(acDBObjColl)
            Dim acRegion As Region = myRegionColl(0)
            acBlkTblRec.AppendEntity(acRegion)
            acTrans.AddNewlyCreatedDBObject(acRegion, True)
            '' Dispose of the in memory object not appended to the database
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddRegion")]
public static void AddRegion()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create an in memory circle
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 2, 0);
            acCirc.Radius = 5;
            // Adds the circle to an object array
            DBObjectCollection acDBObjColl = new DBObjectCollection();
            acDBObjColl.Add(acCirc);
            // Calculate the regions based on each closed loop
            DBObjectCollection myRegionColl = new DBObjectCollection();
            myRegionColl = Region.CreateFromCurves(acDBObjColl);
            Region acRegion = myRegionColl[0] as Region;
            acBlkTblRec.AppendEntity(acRegion);
            acTrans.AddNewlyCreatedDBObject(acRegion, true);
            // Dispose of the in memory circle not appended to the database
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub AddRegion()
    ' Define an array to hold the
    ' boundaries of the region.
    Dim curves(0 To 0) As AcadCircle
    ' Create a circle to become a
    ' boundary for the region.
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2
    center(1) = 2
    center(2) = 0
    radius = 5#
    Set curves(0) = ThisDrawing.ModelSpace.AddCircle _
                                     (center, radius)
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ZoomAll
GMT+8, 2026-11-1 07:08
