AutoCAD 2024 开发者帮助
创建实体填充区域 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 907| 评论: 0|原作者: admin|来自: AutoCAD
创建实体填充区域 (.NET)
您可以创建填充颜色的三角形和四边形区域。创建填充区域时,将 FILLMODE 系统变量设置为关闭以提高性能,并在创建填充后重新打开。
创建四边形实体填充区域时,第三点和第四点的顺序决定了其形状。比较下图:
前两点定义多边形的一条边。第三点的定义与第二点对角线相反。如果将第四个点设置为等于第三个点,则创建一个填充三角形。
创建实体填充对象
以下示例使用坐标 (0, 0, 0)、(5, 0, 0)、(5, 8, 0) 和 (0, 8, 0) 在模型空间中创建一个四边形实体(领结)。它还使用坐标 (10, 0, 0)、(15, 0, 0)、(10, 8, 0) 和 (15, 8, 0) 创建矩形四边形实体。
VB.NET
<CommandMethod("Add2DSolid")> _
Public Sub Add2DSolid()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a quadrilateral (bow-tie) solid in Model space
        Using ac2DSolidBow As Solid = New Solid(New Point3d(0, 0, 0), _
                                                New Point3d(5, 0, 0), _
                                                New Point3d(5, 8, 0), _
                                                New Point3d(0, 8, 0))
            acBlkTblRec.AppendEntity(ac2DSolidBow)
            acTrans.AddNewlyCreatedDBObject(ac2DSolidBow, True)
        End Using
        '' Create a quadrilateral (square) solid in Model space
        Using ac2DSolidSqr As Solid = New Solid(New Point3d(10, 0, 0), _
                                                New Point3d(15, 0, 0), _
                                                New Point3d(10, 8, 0), _
                                                New Point3d(15, 8, 0))
            acBlkTblRec.AppendEntity(ac2DSolidSqr)
            acTrans.AddNewlyCreatedDBObject(ac2DSolidSqr, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("Add2DSolid")]
public static void Add2DSolid()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a quadrilateral (bow-tie) solid in Model space
        using (Solid ac2DSolidBow = new Solid(new Point3d(0, 0, 0),
                                        new Point3d(5, 0, 0),
                                        new Point3d(5, 8, 0),
                                        new Point3d(0, 8, 0)))
            acBlkTblRec.AppendEntity(ac2DSolidBow);
            acTrans.AddNewlyCreatedDBObject(ac2DSolidBow, true);
        // Create a quadrilateral (square) solid in Model space
        using (Solid ac2DSolidSqr = new Solid(new Point3d(10, 0, 0),
                                        new Point3d(15, 0, 0),
                                        new Point3d(10, 8, 0),
                                        new Point3d(15, 8, 0)))
            acBlkTblRec.AppendEntity(ac2DSolidSqr);
            acTrans.AddNewlyCreatedDBObject(ac2DSolidSqr, true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub Add2DSolid()
    Dim solidObj As AcadSolid
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    Dim point3(0 To 2) As Double
    Dim point4(0 To 2) As Double
    ' Define the solid
    point1(0) = 0#: point1(1) = 0#: point1(2) = 0#
    point2(0) = 5#: point2(1) = 0#: point2(2) = 0#
    point3(0) = 5#: point3(1) = 8#: point3(2) = 0#
    point4(0) = 0#: point4(1) = 8#: point4(2) = 0#
    ' Create the solid object in model space
    Set solidObj = ThisDrawing.ModelSpace.AddSolid _
                                    (point1, point2, point3, point4)
    ' Define the solid
    point1(0) = 10#: point1(1) = 0#: point1(2) = 0#
    point2(0) = 15#: point2(1) = 0#: point2(2) = 0#
    point3(0) = 10#: point3(1) = 8#: point3(2) = 0#
    point4(0) = 15#: point4(1) = 8#: point4(2) = 0#
    ZoomAll
GMT+8, 2026-11-20 14:37
