AutoCAD 2024 开发者帮助
创建 Arc 对象 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 987| 评论: 0|原作者: admin|来自: AutoCAD
创建 Arc 对象 (.NET)
本示例在模型空间中创建一个圆弧,其中心点为 (6.25,9.125,0),半径为 6,起始角为 1.117(64 度),结束角为 3.5605(204 度)。
VB.NET
<CommandMethod("AddArc")> _
Public Sub AddArc()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create an arc that is at 6.25,9.125 with a radius of 6, and
        '' starts at 64 degrees and ends at 204 degrees
        Using acArc As Arc = New Arc(New Point3d(6.25, 9.125, 0), _
                                     6, 1.117, 3.5605)
            acBlkTblRec.AppendEntity(acArc)
            acTrans.AddNewlyCreatedDBObject(acArc, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddArc")]
public static void AddArc()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create an arc that is at 6.25,9.125 with a radius of 6, and
        // starts at 64 degrees and ends at 204 degrees
        using (Arc acArc = new Arc(new Point3d(6.25, 9.125, 0),
                            6, 1.117, 3.5605))
            acBlkTblRec.AppendEntity(acArc);
            acTrans.AddNewlyCreatedDBObject(acArc, true);
        // Save the new line to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub AddArc()
    ' Define the center point
    Dim ptCen(0 To 2) As Double
    ptCen(0) = 6.25: ptCen(1) = 9.125: ptCen(2) = 0#
    ' Create an Arc object in model space
    Dim arcObj As AcadArc
    Set arcObj = ThisDrawing.ModelSpace.AddArc(ptCen, 6#, 1.117, 3.5605)
GMT+8, 2026-10-30 02:56
