AutoCAD 2024 开发者帮助
文档窗口的位置和大小 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 676| 评论: 0|原作者: admin|来自: AutoCAD
文档窗口的位置和大小 (.NET)
使用该对象可以修改任何文档窗口的位置和大小。可以使用该属性最小化或最大化“文档”窗口,并且可以使用该属性查找“文档”窗口的当前状态。DocumentWindowStateWindowState
调整活动“文档”窗口的大小
本示例使用 Location 和属性将 Document 窗口的位置和大小设置为 400 像素宽 x 400 像素高。Size
VB.NET
Imports Autodesk.AutoCAD.Windows
<CommandMethod("SizeDocumentWindow")> _
Public Sub SizeDocumentWindow()
    ''Size the Document window
    acDoc.Window.WindowState = Window.State.Normal
    '' Set the position of the Document window
    Dim ptDoc As System.Windows.Point = New System.Windows.Point(0, 0)
    acDoc.Window.DeviceIndependentLocation = ptdoc
    '' Set the size of the Document window
    Dim szDoc As System.Windows.Size = New System.Windows.Size(400, 400)
    acDoc.Window.DeviceIndependentSize = szDoc
C#
using Autodesk.AutoCAD.Windows;
[CommandMethod("SizeDocumentWindow")]
public static void SizeDocumentWindow()
    //Size the Document window
    // Works around what looks to be a refresh problem with the Application window
    acDoc.Window.WindowState = Window.State.Normal;
    // Set the position of the Document window
    System.Windows.Point ptDoc = new System.Windows.Point(0, 0);
    acDoc.Window.DeviceIndependentLocation = ptDoc;
    // Set the size of the Document window
    System.Windows.Size szDoc = new System.Windows.Size(400, 400);
    acDoc.Window.DeviceIndependentSize = szDoc;
VBA/ActiveX 代码参考
    ThisDrawing.Width = 400
    ThisDrawing.Height = 400
最小化和最大化活动的“文档”窗口
VB.NET
<CommandMethod("MinMaxDocumentWindow")> _
Public Sub MinMaxDocumentWindow()
    ''Minimize the Document window
    acDoc.Window.WindowState = Window.State.Minimized
    MsgBox("Minimized", MsgBoxStyle.SystemModal, "MinMax")
    ''Maximize the Document window
    acDoc.Window.WindowState = Window.State.Maximized
    MsgBox("Maximized", MsgBoxStyle.SystemModal, "MinMax")
C#
[CommandMethod("MinMaxDocumentWindow")]
public static void MinMaxDocumentWindow()
    //Minimize the Document window
    acDoc.Window.WindowState = Window.State.Minimized;
    System.Windows.Forms.MessageBox.Show("Minimized" , "MinMax");
    //Maximize the Document window
    acDoc.Window.WindowState = Window.State.Maximized;
    System.Windows.Forms.MessageBox.Show("Maximized" , "MinMax");
VBA/ActiveX 代码参考
    '' Minimize the Document window
    ThisDrawing.WindowState = acMin
    MsgBox "Minimized"
    ThisDrawing.WindowState = acMax
    MsgBox "Maximized"
查找活动“文档”窗口的当前状态
VB.NET
<CommandMethod("CurrentDocWindowState")> _
Public Sub CurrentDocWindowState()
    System.Windows.Forms.MessageBox.Show("The document window is " & _
    acDoc.Window.WindowState.ToString(), "Window State")
C#
[CommandMethod("CurrentDocWindowState")]
public static void CurrentDocWindowState()
    System.Windows.Forms.MessageBox.Show("The document window is " +
    acDoc.Window.WindowState.ToString(), "Window State");
VBA/ActiveX 代码参考
    Dim CurrWindowState As Integer
    Dim msg As String
    CurrWindowState = ThisDrawing.WindowState
    msg = Choose(CurrWindowState, "Normal", _
                 "Minimized", "Maximized")
    MsgBox "The document window is " + msg
GMT+8, 2026-9-6 07:35
