AutoCAD 2024 开发者帮助
向集合对象添加新成员 (.NET)
2024-5-18 19:13| 发布者: admin| 查看: 788| 评论: 0|原作者: admin|来自: AutoCAD
向集合对象添加新成员 (.NET)
若要向集合中添加新成员,请使用该方法。例如,以下代码创建一个新图层并将其添加到“图层”表中:Add
VB.NET
<CommandMethod("AddMyLayer")> _
Public Sub AddMyLayer()
  '' Get the current document and database, and start a transaction
      '' Returns the layer table for the current database
      Dim acLyrTbl As LayerTable
      acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, _
                                   OpenMode.ForRead)
      '' Check to see if MyLayer exists in the Layer table
      If Not acLyrTbl.Has("MyLayer") Then
          '' Open the Layer Table for write
          acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite)
          '' Create a new layer table record and name the layer "MyLayer"
          Using acLyrTblRec As LayerTableRecord = New LayerTableRecord
              acLyrTblRec.Name = "MyLayer"
              '' Add the new layer table record to the layer table and the transaction
              acLyrTbl.Add(acLyrTblRec)
              acTrans.AddNewlyCreatedDBObject(acLyrTblRec, True)
          End Using
          '' Commit the changes
          acTrans.Commit()
      End If
      '' Dispose of the transaction
  End Using
C#
[CommandMethod("AddMyLayer")]
public static void AddMyLayer()
  // Get the current document and database, and start a transaction
      // Returns the layer table for the current database
      LayerTable acLyrTbl;
                                   OpenMode.ForRead) as LayerTable;
      // Check to see if MyLayer exists in the Layer table
      if (acLyrTbl.Has("MyLayer") != true)
          // Open the Layer Table for write
          acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForWrite);
          // Create a new layer table record and name the layer "MyLayer"
          using (LayerTableRecord acLyrTblRec = new LayerTableRecord())
              acLyrTblRec.Name = "MyLayer";
              // Add the new layer table record to the layer table and the transaction
              acLyrTbl.Add(acLyrTblRec);
              acTrans.AddNewlyCreatedDBObject(acLyrTblRec, true);
          // Commit the changes
          acTrans.Commit();
      // Dispose of the transaction
VBA/ActiveX 代码参考
Sub AddMyLayer()
    Dim newLayer as AcadLayer
    Set newLayer = ThisDrawing.Layers.Add("MyLayer")
GMT+8, 2026-10-27 23:44
