AutoCAD 2024 开发者帮助
扩展属性自定义
2024-5-18 19:13| 发布者: admin| 查看: 930| 评论: 0|原作者: admin|来自: AutoCAD
扩展属性自定义
The IOPMPropertyExtension interface is a collection of miscellaneous property enhancements. The GetDisplayName() method is used to replace the type information name of a property with a more readable alternative. The Editable() method is used to make properties read-only in the Properties palette. The ShowProperty() method is used to temporarily remove a property from the Property Inspector's grid display.
  1. 增强属性显示
GMT+8, 2026-10-25 09:18
