AutoCAD 2024 开发者帮助
示例 3:获取窗口坐标
2024-5-18 19:12| 发布者: admin| 查看: 623| 评论: 0|原作者: admin|来自: AutoCAD
示例 3:获取窗口坐标
此示例演示如何使用 和 获取视口的显示坐标。当您绘制依赖于视口的物理布局的图形时,此功能非常方便,例如随视口的大小或边框而变化的图标和标记。绘制的图形将随着平移和缩放而变化。AcGiViewportDraw::polylineDc()AcGiViewport::getViewportDcCorners()
该示例在视口的右上角绘制一个框。框的宽度和高度始终是视口最短尺寸的十分之一,并且框位于视口右上角左侧的视口最短尺寸的十分之一的中心:
      void
      AsdkIconSamp::subViewportDraw(AcGiViewportDraw* pV)
      // Get the       current viewport's display coordinates.
      AcGePoint2d       lower_left, upper_right;
      pV->viewport       ().getViewportDcCorners(lower_left,
      upper_right);
      double xsize =       upper_right.x - lower_left.x;
      double ysize =       upper_right.y - lower_left.y;
      xsize /= 10.0;
      ysize /= 10.0;
      double xcenter       = upper_right.x - xsize;
      double ycenter       = upper_right.y - ysize;
      double       half_xsize = xsize / 2.0;
      double       half_ysize = ysize / 2.0;
      // Create a       unit square.
      const int       num_verts = 5;
      AcGePoint3d       verts[num_verts];
      for (int i = 0;       i < num_verts; i++) {
      verts[i].x =       xcenter;
      verts[i].y =       ycenter;
      verts[i].z =       0.0;
      verts[0].x -=       half_xsize;
      verts[0].y +=       half_ysize;
      verts[1].x +=       half_xsize;
      verts[1].y +=       half_ysize;
      verts[2].x +=       half_xsize;
      verts[2].y -=       half_ysize;
      verts[3].x -=       half_xsize;
      verts[3].y -=       half_ysize;
      verts[4] =       verts[0];
      pV-       >subEntityTraits().setColor(kRed);
      pV->geometry       ().polylineDc(num_verts, verts);
void
AsdkIconSamp::viewportDraw(AcGiViewportDraw* pV)
    pV->viewport().getViewportDcCorners(lower_left,
        upper_right);
    xsize /= 10.0;
    ysize /= 10.0;
        verts[i].z = 0.0;
    pV->subEntityTraits().setColor(kRed);
    pV->geometry().polylineDc(num_verts, verts);
  1. 转换示例
GMT+8, 2026-10-23 12:06
