AutoCAD 2024 开发者帮助
示例 1:坐标系
2024-5-18 19:12| 发布者: admin| 查看: 634| 评论: 0|原作者: admin|来自: AutoCAD
示例 1:坐标系
此示例采用在模型坐标中定义的线段,并在眼睛坐标和显示坐标中创建其等效项。显示时,所有行将重叠。
 void
      AsdkCoordSamp::subViewportDraw       (AcGiViewportDraw* pV)
 pV->subEntityTraits().setFillType(kAcGiFillAlways);
 const int count = 3;
 AcGePoint3d verts[count];
      verts[0] =       AcGePoint3d(0.0, 0.0, 0.0);
 verts[1] = AcGePoint3d(1.0, 0.0, 0.0);
 verts[2] = AcGePoint3d(1.0, 1.0, 0.0);
      // Draw model space line segment.
      pV-       >subEntityTraits().setColor(kBlue);
 pV->geometry().polygon(count, verts);
 // Compute its representation in eye space.
 AcGeMatrix3d mat;
      pV->viewport       ().getModelToEyeTransform(mat);
 for (int i = 0; i < count; i++) {
 verts[i].x += 0.01;
 verts[i].y += 0.01;
 verts[i].z += 0.01;
      verts[i].transformBy       (mat);
 // Display the eye coordinate equivalent of the
 // model space polygon.
      pV->subEntityTraits().setColor(kGreen);
      pV-       >geometry().polygonEye(count, verts);
 // Convert from eye to display coordinates.
      verts[i].x += 0.01;
 verts[i].y += 0.01;
 verts[i].z += 0.01;
 // Draw the display space equivalent of the
      pV->subEntityTraits       ().setColor(kRed);
 pV->geometry().polygonDc(count, verts);
void
AsdkCoordSamp::viewportDraw(AcGiViewportDraw* pV)
    pV->subEntityTraits().setColor(kBlue);
    // Compute the line's representation in eye space.
    AcGeMatrix3d mat;
    pV->viewport().getModelToEyeTransform(mat);
        verts[i].x += 0.01;
        verts[i].y += 0.01;
        verts[i].z += 0.01;
        verts[i].transformBy(mat);
    pV->geometry().polygonEye(count, verts);
    for (i = 0; i < count; i++) {
        verts[i].x += 0.01;
        verts[i].y += 0.01;
        verts[i].z += 0.01;
    pV->subEntityTraits().setColor(kRed);
  1. 转换示例
GMT+8, 2026-11-7 06:44
