AutoCAD 2024 开发者帮助
网孔
2024-5-18 19:12| 发布者: admin| 查看: 931| 评论: 0|原作者: admin|来自: AutoCAD
网孔
网格是存储顶点的参数化矩形网格的有效方法。网格的几何图形按行顺序指定为行数、列数和顶点列表:
virtual Adesk::Boolean
AcGiWorldGeometry::mesh(
    const Adesk::UInt32 rows,
    const Adesk::UInt32 columns,
    const AcGePoint3d*  pVertexList,
    const AcGiEdgeData* pEdgeData = NULL,
    const AcGiFaceData* pFaceData = NULL,
    const AcGiVertexData* pVertexData = NULL) const = 0;
该函数具有三个可选参数,用于将属性数据附加到边、面或顶点。对于网格中的边,可以附加颜色、图层、线型、GS 标记和可见性属性。例如,您可以使用将不同的颜色附加到网格的每个边。在颜色列表中,首先列出所有行边的颜色,然后列出所有列边的颜色。下图显示了示例网格的边属性数据的顺序:mesh()AcGiEdgeData::setColors()
以下示例代码创建网格并使用边数据和人脸数据指定颜色。它构造了一个带有青色行和绿色列的四乘四网格。
      Adesk::Boolean
      AsdkMeshSamp::subWorldDraw(AcGiWorldDraw* pW)
      Adesk::UInt32       i, j, k;
      Adesk::UInt32       numRows = 4;
      Adesk::UInt32       numCols = 4;
      AcGePoint3d       *pVerts =
      new       AcGePoint3d[numRows * numCols];
      for (k = 0, i =       0; i < numRows; i++) {
      for (j = 0; j       < numCols; j++, k++) {
      pVerts[k].x =       (double)j;
      pVerts[k].y =       (double)i;
      pVerts[k].z =       0.;
      // Construct an       array of colors to be applied to each
      // edge of the       mesh.  Here, let the rows be cyan and
      // the columns       be green.
      AcGiEdgeData       edgeInfo;
      Adesk::UInt32       numRowEdges = numRows * (numCols - 1);
      Adesk::UInt32       numColEdges = (numRows - 1) * numCols;
      Adesk::UInt32       numEdges = numRowEdges + numColEdges;
      short       *pEdgeColorArray = new short[numEdges];
      for (i = 0; i       < numEdges; i++) {
      pEdgeColorArray[i] =
      i <       numRowEdges ? kCyan : kGreen;
      edgeInfo.setColors(pEdgeColorArray);
      // Make the       first face transparent and the rest
      // different       colors.
      Adesk::UInt32       numFaces = (numRows - 1)
      * (numCols -       1);
      Adesk::UInt8       *pFaceVisArray =
      new       Adesk::UInt8[numFaces];
      short       *pFaceColorArray = new short[numFaces];
      AcGiFaceData       faceInfo;
      faceInfo.setVisibility(pFaceVisArray);
      for (i = 0; i       < numFaces; i++) {
      pFaceVisArray       [i] =
      i ?       kAcGiVisible : kAcGiInvisible;
      pFaceColorArray[i] = (short)(i + 1);
      faceInfo.setColors(pFaceColorArray);
      // If the fill       type is kAcGiFillAlways, then a shell,
      // mesh, or       polygon will be interpreted as faces;
      // otherwise,       they will be interpreted as edges.
      // Output mesh       as faces.
      pW-       >subEntityTraits().setFillType(kAcGiFillAlways);
      pW->geometry       ().mesh(numRows, numCols, pVerts, NULL,
      &faceInfo);
      // Output mesh       as edges over the faces.
      pW-       >subEntityTraits().setFillType(kAcGiFillNever);
      &edgeInfo);
      delete []       pVerts;
      delete []       pEdgeColorArray;
      delete []       pFaceColorArray;
      delete []       pFaceVisArray;
      return       Adesk::kTrue;
对于网格中的面,可以附着颜色、图层、GS 标记、法线和可见性特征。要为网格中的面指定属性,请按行顺序列出面的值,如下图所示:
网格的顶点数据按顶点列表中的顺序列出。可以设置的属性是法线和方向。AcGiVertexData
本教程中的主题
  1. 能见度
  1. 原
GMT+8, 2026-10-23 07:58
